Trying to use a hard-wired sounder on EMS Firepoint 5000 system
Connected it to correct internal socket, but only radio Sounders work when active.
Tested sounder by connecting it directly to a battery and it sounds fine
Is there a setting needs changed on the board or programming.
(This is a hobby system, not looking for an upgrade, or advice to ‘bin it’)
Thanks
EMS FirePoint is obsolete now
Sorry for not much help
As it’s a hobby system, we can ignore the fact that it’s obsolete… @willie do you have a multi meter you can use to test voltage? I’m not familiar with that system, but checking to see if any voltage is coming out of that socket would be a good place to start.
Have you already had a look through the manual regarding programming? https://emsgroup.co.uk/wp-content/uploads/2018/10/System-5000-Engineers-Operating-Guide-Iss4.pdf
OK my bad Zach
Yeah as Zach said, try a multimeter
