FAST has been around for a bit but I cannot exactly date back the time they were first established but somewhere in the 80s the IRC-1 made its showcase
In 1989 FAST Showed its first brochure of the IRC-3 Labeled as the “Response 3000” fast forward 1 year to 1990 another brochure showed up with the FCC, an even larger version of the IRC-3 now boasting the Response 3000 name while the smaller sibling panel got the IRC-3 name. In 1991 the Response 3000 would later become the FCC panel, dropping the Response 3000 name all together as shown in the ad posted by Illomenga23
The IRC handled well over 5000 points, addressable or conventional while the FCC would support over 40,000. These panels used the CM2’s which were a sort of transponder panel. They had a dedicated CPU and 2 card slots for either a ZAS-1 Analog CLIP card, a ZB8 Zone card or any other combination you wanted. Each CM ‘Module’ would only support 2 cards per module so in order to Achieve a larger system cap, you would need more CM Control modules. These systems had a wide variety of Annunciator Options, One of which being the SAN Series Annunciators, CMDN Annunciators, RASP Annunciators, An onboard printer module I do not remember the name of, the CCA Computerized Color Annunciator, and a terminal. EVAC was possible through the FCCA and had a capacity for 6 audio channels. Voice would be handled first through the RAMM-A Then later with the MVM. The MVM Had the same design as a CM1N but with some slight differences and hardware changes for audio. The RAMM-A and MVM Allowed for a maximum of 500 individual message phrases but the more channels added to the system would impact the amount of record time you could use.
Notable installs for them were DEN Airport, Luxor hotel, Salt palace Convention center, Elitch garden’s Denver and im sure many more im missing.
The IRC-3 would become very popular even outside the US with some notable installation being the Bejing west railway station, The Intel plant in Dublin, Metropolitan Life building Ottawa.
The LSS Series of panels were the conventional option with the larger panel being the LSS4 which supported up to 36 zones. The panel included an RS-485 bus allowing the use of annunciators like the SAN Series.
While in edward’s land they had introduced the ESA2000 in I believe 1992?, A hybrid conventional/Addressable panel Similar to that of the 4100 (Best described by CJ9899) These panels were DOS Based and not too popular from what i understand but a notable installation of the panel would be the Palisades center in New work. They used their own addressable protocol but I do not know much about them.
In around 1992-1993 Edwards bought FAST to form EST and quickly started slapping the new shiny EST name over the original FAST one. In around
In 1994 EST Would introduce Signature series in A brochure, EST Would later release the ZAS-2, A SIGA Addressable card for the IRC-3/FCC
In 1995 EST Would introduce EST2, the first native SIGA Panel with 1000 points and EVAC. These panels would inherit a lot of the functions and control from the IRC/FCC and even use the SAN Annunciators as well
1995-1996 would dawn the EST3, a panel that from my understanding was in Development since 1994? But would not see full release until roughly 1995/1996. The panel also inherited a lot of the IRC-3/FCC Traits and became their new flagship panel with 8 Channels of audio, 64 panels and 160,000 Devices across all 64.
Cannot comment on EST1 as I do not know its history well
This is all the information i can provide at the moment but if i was wrong somewhere somebody please do correct me as all this information is best to how i understand it looking through a lot of documentation and speaking to some techs
I will add to this list as I gather more information or remember things to add
