Hi guys in new property gone blank on testing
put key in my unit
esp MAGPRO - CP
im supposed to pull down but cant ![]()
Iâm assuming youâre located in the UK? From what I can gather, testing procedure seems to be something like this:
- Call your monitoring company and inform them that youâre going to do your weekly test
- Test a different call point each week - find the call point you want to test
- Activate and then reset the call point. Most of them are resettable, so you can press them, or you can key activate them. Looks like youâve got an ESP system, so what youâd do is press the call point, then take your reset key and insert it into the bottom slot of the call point. Push it up until the yellow and black activated flag disappears back into the call point. To key activate it, all you have to do is insert the key into the bottom slot and push up until the alarms sound.
- Silence and reset the panel. On the ESP panel, there should be a âsounder silenceâ button and then a âsystem resetâ button you need to press. Unfortunately, the ESP site doesnât let me read product manuals so Iâm just assuming that the buttons are laid out like that. Make sure that by the end, the only LED lit should be a green âNormalâ one, and the panelâs display reads something to the effect of âSystem normalâ.
If youâve got any questions, feel free to respond! Also, pictures would help me immensely to see what youâre looking at. Weâve got an attachments option for you to add pictures to your post.
Hope I could help!
