Stamford Train Station, Stamford, CT:
Panel is a Simplex 4100U or 4100ES
Signals: 4903 horn or speaker strobes
Pulls: 2901-9795s (T- Bars)
Smokes: TrueAlarms
Smokes: TrueAlarms
Tron Lightcycle/Run, Magic Kingdom, FL
Panel: EST Addressable panel (likely an EST3X or EST4)
Pulls: SIGA-270s
Detectors: SIGA-PDs (black)
Signals: LED Genesis speaker/strobes (wall mount, black), regular Genesis speaker/strobes (ceiling mount, black), WG4 weatherproof speaker/strobes (red, white in restrooms), and Integrity strobes (red, located in restrooms)
This will be a big post about various churches that I have been to:
Holy Spirit Church, Stamford, CT
Panel: Some sort of newer Fire-Lite panel
Voice Evac Panel: Audiosone/Silent Knight/Sigcom AU-360 panel in vestibule
The message is the standard SK female message, like this: https://www.youtube.com/watch?v=jlqgMfqBCao
Pulls:
Fire-Lite BG-12s
N/As:
SpectrAlert Advance Speaker Strobes
System Sensor SR Strobes
Detectors:
Holy Spirit/St. Aloysius School, Stamford, CT (on the HS Church property)
Panel:
Pulls:
N/As:
(Detectors are unknown, I will update on this when I go there for youth ministry meetings)
Church of St. Cecilia, Stamford, CT:
Panel: Fire-Lite MS9200
Annunciator: Fire-Lite LCD-80F
Pulls: Fire-Lite BG12s
Alarms: SpectrAlert Classics
Detectors:
Peninsula Library & Historical Society (built in 1964): Peninsula, Ohio (north of Akron)
Panel is a Simplex 4240 series
Initiating devices: two Simplex 4251-1s and a 4251-20 series pull, which was a replacement for the former
ESL 400 series smoke detectors
an unknown heat sensor
Signaling devices:
Simplex 4040 (Federal 350A) and one 4050 (Faraday 5400)
a lone Simplex 2901-9500 (Faraday 6100) in the local history room
A most interesting system, especially with the unusual combination of devices! Not sure I’ve ever seen/heard of a 2901-9500 either! (is it an AC version of the 2901-9838?)
You oughta try to save most of that if it’s ever replaced!
this building is not getting demolished anytime soon. but I will inform Old School Fire Alarms about this. I never knew a building this small could have a vintage fire alarm system. I also found some 1960s Johnson Control and Honeywell thermostats.
yes, the 2901–9500 is an AC 9838. I’m not sure what voltage the signaling devices operate at as I couldn’t see any labels.
I think this building had some component upgrades and replacements over the years (the gray 4040 was the only original signaling device I found (the others were probably replacements). I think the ESL smoke detectors were installed in the 70s or 80s (probably a code requirement for a national park.) and are on their own IDC.
Speaking of libraries, my local library got a fire alarm system upgrade!
Harry Bennett Library, Stamford, CT (built in 2000)
Original System:
Pulls:
Alarms:
New System:
Panels:
Pulls:
Alarms:
My local library used to have a Simplex 4002 with 2901-9838 horns on 4903-9105 strobe plates. Last year, they remodeled the entire library and added an addition. They replaced the system with a new addressable Siemens FA panel (I don’t know what kind). This is not surprising as Siemens is being used on almost all new systems in my area. The signals are rebranded wall mounted Wheelock led3 horn/strobes and remote strobes. There are also addressable Siemens smoke and heat detectors.
Greenwich Catholic School, Greenwich, CT:
Panel:
Pulls:
Alarms:
AMC Livonia 20 (Livonia)
Annunciators/panel:
<At least one Simplex 4603-9101
<Panel unknown, presumably a Simplex 4100 or 4120
Detectors:
<None noticed
Pull stations:
<Simplex 4099-9001 models behind STI Stopper II covers
Notification appliances:
<One Wheelock MT4 horn/strobe above a fire department sprinkler connection in the back (viewable in Street View)
<Red Simplex 4904-series strobes on the walls
<White Simplex 4902-series speakers on the ceilings
One of the churches in my area had what I believe was a Cerberus Pyrotronics MXL system. The system consisted of addressable smoke detectors, heat detectors, and pull stations. In the main chapel, there were s-hps-mcs-w speaker strobes and u-mcs-w remote strobes. Everywhere else in the building and the attached school, there were u-hn-mcs-w horn strobes and the same remote strobes. In the past couple of months, they upgraded to a new Autocall 4100es system with addressable smokes, heats, and pulls. The entire church building and the entire school building now have red conventional TrueAlert speaker strobes and remote strobes in place of the old speaker strobes, horn strobes, and remote strobes.
This will be a big update about a lot of systems:
Primavera Restaurant, North Salem, NY:
Panel: FA system is tied into security system
Pulls: BG-12s
Alarms: SpectrAlert Classics and one Advance
Detectors: i3s
Acme Markets, Greenwich, CT:
Panels: EST2 and a Fire-Lite MS-5012 that is not in service
Pulls: 270-SPOs and one SIGA-270
N/As: Edwards 202-5A-T strobes (evac message most likely plays over PA system speakers)
ShopRite, Stamford, CT:
Panel: Cerberus Pyrotronics/Siemens MXL
Pulls: Unknown (most likely Siemens MS-151s)
Alarms: U-MH-MCS and U-MCS strobes
Italian Center, Stamford, CT
Old System: Simplex 4208 (most likely)- removed in the 90s or 2000s
New System: Kidde rebranded EST3 (formerly an EST2 or EST3)
Pulls:
N/As:
Detectors:
Those look more like Siemens u-mh-mcs’ they’re basically mini horn-strobes. I say that because they look to have those blue murata horns in them, like these
Cape May - Lewes Ferry Terminals
Both terminals have identical systems. For some reason all the initiating devices were replaced a few years ago, but the signals remained.
Panel: Unknown Siemens/Cerberus Pyrotronics Addressable Panel
Pulls: HMS-Ds (Likely replaced MSI-10Bs)
Detectors: OH921s (Replaced FP-11s)
Signals: UMMT-S17s and U-S17s
Ocean County Mall - Toms River, NJ
Boscov’s
Panel: Unknown (Likely EST given the initiating devices)
Pulls: SIGA-278s
Detectors: SIGA-PSes (rebranded by ADT)
Signals: Wheelock ASes that are slowly being replaced by Exceeders
Macy’s/JCPenney
I haven’t been in these stores much to notice the devices, but I don’t see any in images online.
Main Mall Area
Panel: Simplex Addressable Panel (Likely a 4100ES or 4100U)
Pulls: Either 4099-9001s or 4099-9006s and a few recently added 4099-9004s
Detectors: Addressable TrueAlarms
Signals: TrueAlerts (White, both wall and ceiling mount) and at least 4 recently added TrueAlertESes (Red, wall mount)
I may have posted this long ago, but maybe a fresh set of eyes can identify this FACP/annunicator? This is what used to be part of the local college I went to for the fire systems course. Obviously, by the time I got there, the system was long gone and replaced with a Multi Node Notifier system. The bells were Edwards 439s and Wheelock MBs, all 10".
Also a random other pic I found, sorry it is small, it wasn’t mine and from a ‘school condition assessment’ in my province. The website has been down for some time, but beforehand there was a public server with all these school condition assessments. Basically a thorough examination of the entire building and to assess whether to fix all the repairs needed or just close and build new. This was the reason why many FA systems in my area schools got replaced in the early and late 2000s. Beforehand you could find an abundance of cool, old and unique systems. Here are a few I have saved. Again, sorry for the quality.
-Rare Simplex 2001 panel,.
-Simplex 4246 FACP.
-A few different Edwards FACPs. Actually one on the top might be a Standard, Unelco or Cincinatti FACP, popular amonst my area as well before Edwards took over. Most schools had the standard single stroke bells or vibrating bells.
-Old IBM FACP.
Fairfield College Preparatory School, Fairfield, CT:
Pulls:
Alarms:
Detectors:
Longhorn Steakhouse - Mays Landing, NJ
Panel: ADT Unimode 9050UD (ADT-ANN-80 Annunciator)
Pulls: ADT-BG-12LXes
Detectors: None
Signals: System Sensor P2Ws, PC2Ws, and SCWs
Daval’s Used Furniture & Antiques (Rutland Charter Township)
<This store still has a working, vintage First Alert SA88 wall-mounted above a door. There is no centralized alarm system.
Beech Elementary School (Redford Township) - The current incarnation of this school is located in the former Pearson Junior High building. Per unofficial Facebook pages, this school has had a total of three systems. This post covers the gym, a portion of one hallway, and portions of the exterior.
Annunciators/panels
<First system: Unknown, presumably a National Time (Natsco) type 2000-series
<Second system: Unknown, presumably EST
<Current system: Unknown
Detectors
<None noticed across all systems
Pull stations
<First system: Unknown, presumably Natsco type 620Ms or 341s
<Second system: EST 270-SPO types
<Current system: Fire-Lite NBG-12LX models behind STI Stopper II covers
<First system: Based on the square metal plates covering the old devices, they were either Natsco type 311F or 411F horns. Rectangular plates plus wall scars indicate there were P806 bells used for class change, and several P808/P810 bells–some without their cast-iron guards–survive outside, albeit disconnected.
<Second system: EST EGCF-HDMVH horn/strobes on the ceilings and walls throughout the building
<Current system: Red Wheelock Exceder wall-mount LED speaker/strobes with white Exceder ceiling-mount LED speaker/strobes throughout the building
Notably, there is also a Wheelock ET70WP series speaker/strobe outside, near a mechanical room.
