Fire alarms in roblox.
How did you make that?
Can I have the IP for your server?
No, you can’t.
It’s private.
Here are some panels that I have made on the server:
Quick Alert 2200M, installed in a fishing lodge.
Quick Alert A108C panel, WIP. It’s in the Patton tower. It also does security, walk test, and can be hooked to a monitoring station.
How can you make multiplex systems in minecraft?
It’s quite complicated. Involves command blocks and lots of commands that are not in the vanilla game yet.
Are they in snapshots yet?
Well I was just wondering because if you guys had fire control panels there I would want to be apart of that server.
I would love to go on that server and see some in action.
Hey Andrew, do most of your systems rely on command blocks?
Because I consider that cheating
Personally I prefer solid state redstone, as in I could feasibly build it in survival. To each his own.
Did you ever download the map that I was working on with the four zone conventional panel in progress and the glass stoppers? What did you think?
Almost all of the panels on the server are command block based. However, there was an old mechanical Quick Alert panel in the old grocery store, but it got torn down.
I really have to get a new computer so that I can come back to Minecraft.
Yes, my system is that decrepit.
Anyways I have a really good panel going that’s all solid state. I’ll have to finish it. Actually with a slight tweak it can output continuous, but I wanted to design a coding module that modulates the output with various common codes and the ability for “vibratory mode” and “strobe mode.” I also wanted to design some supervisory circuits, which is going to induce some serious gluteal myalgia.
So I can’t join the server
Sorry for the bump but, I found his world do you think I could try it out.
My username is: ccsprague
You could have PM’d him instead of bumping this topic…
(Sorry for backseat moderating, Green! That’s your job!)
Can I request this topic to be locked?
The OP was recently suspended for being underage. Locked.
