So, long story short, my Simplex 4004 broke the other day when it started displaying non-existent troubles after powering it down. After failed attempts to clear the troubles, I realized something probably internally fried the board pretty bad (possibly the Wheelock 712-24? Guess what I’m never wiring up to a panel again?). So, I just put it on eBay for parts. Hopefully I can make $20 on it.
Luckily, though, I was able to quickly come across a replacement, a Fire-Lite MS-2. Personally, I have always hated Fire-Lite and similar brand panels (no offence to Fire-Lite fans or the company, it’s just an opinion) for a couple reasons. I just couldn’t pass this one up because of the fact it was only $75, though, and I figured it could be temporary until I can get another Simplex panel. I won the auction this afternoon and it’s already on it’s way. I have a few questions about it, though, since I have never worked with a non-Simplex panel. Just FYI, I have already read several documents and diagrams on the MS-2.
First of all, how does the grounding work? The pictures of the actual unit show no wire already going into the Earth terminal on the panel, and I don’t know how to properly ground it.
Second of all, I don’t yet have the proper resistors for it. Is it safe to temporarily power up and test with devices without resistors? Also, do I need resistors across the relay terminals, in addition to the zones and NAC?
Finally, my most important question is what alarms can I even use on it? One of the reasons I hate these panels so much is because they put out FWR, which I know can fry certain devices. What kinds of alarms should I avoid using on it? I think TrueAlerts can’t be used on it? Are electro-mechanical Simplex horns safe to use (4051, 2901-9806, 2901-9838). Can I use Simplex strobes, and do incandescent lights work on these panels? I know System Sensor, Wheelock, and Gentex are preferred devices on these systems, but I like variation. If anyone has a list of general types and series of devices that cannot be used on the MS-2 that I could see, that would greatly be appreciated! Also, is there any kind of device I can purchase that would convert the full wave rectified into regular filtered DC?
Thanks in advance!
