Don’t worry, images will be coming soon…
Notification Appliances:
Wheelock:
CH70-241575W-FR (2x)
ET-1070-LSM-24
MTWP-2475W-FR
RSS-24MCW-FR
Exceeder STW
Exceeder HSR (2x)
ZNS-MCW-FR
34T-24 (3x)
Simplex:
4904-9137 (Very 1st alarm)
2903-9005 (dual-bulb)
2901-9806 (B2)
2903-9101 (Broken)
2901-9833
Faraday/Siemens/Cerberus Pyrotronics:
U-HN-S17
U-EC-MCS
U-MMT-S17
U-MCS
Edwards/EST:
Integrity 757-8A-T (Missing mounting Bracket)
G1F-VM
Integrity 405-7A-T
G1R-HDVM
Gentex:
GOS-24-3075-WW (broken horn)
GOS-24-1575-WR
Commander 1 ST24-110WW
SHG-24-60-WR (broken horn)
System Sensor:
MA/SS-24 (2x)
SC24177
Amazon Brand:
Newer Weatherproof bell (12VDC, malfunctioning)
Spurling F.A. Company:
DPV-3 Bell (6VDC)
Space Age Electronics:
AV32 (with flasher circuit)
Gamewell/FCI:
HE-8F-STW
HP (B4)
Pull Stations:
Simplex:
2099-9769 (newer chevron, first pull station, won’t close)
4099-9006 (addressable module removed)
4251-20
Edwards EST:
278B-1120
270-SPO (4x) (local-alarm version)
279B-1110
Fire-Lite:
BG-12
MSI-10B (addressable module removed)
Federal Signal:
4050-001T
Smoke Detectors:
System Sensor:
2400 (yellowed at base, broken or no idea how to wire it up)
Gamewell/FCI:
71033 Series 60 (no idea how to hook up)
Pyrotronics:
FP-11
Edwards/EST:
Siga-PS (missing base)
Other accessories:
Simplex:
2975-9145 (2903 backbox)
Hope you guys like it!!
On the subject of the system sensor 2400 smoke, you only use the plus and minus for the hookups since it’s a 2 wire detector, you don’t hook up to RA. Also what’s wrong with the 2903-9101 strobe plate? I’ve heard of other collectors having problems with the 3rd generation 9101’s but I have several 3rd generations that I’ve never had problems with.
It should be pretty easy to re-solder to the board. The nice thing about these strobe boards is that most of the parts are standard off the shelf components, and it’s fairly easy to troubleshoot if it stops working.
I suppose I could re-solder it to the board, but based on how far the tube snapped off from the connections, I don’t know if that’s possible. As for finding a replacement part, where do you think I can find it, and what would it be called?
Are you referring to the yellow transformer, or the small glass tube that triggers the strobe?
The only thing I can think of that looks similar both in size and internal structure is a neon indicator lamp, but I’m not sure of a proper name for that component. Since there are no schematics available for these strobe boards, I am trying to reverse engineer my strobe board to figure out the schematic. I believe I have a majority of it figured out, but I still need to find information on a few of the components. If that tube can’t be soldered back on, I’d try one of the aforementioned neon indicator lamps. You can’t make the strobe any worse off if you can’t resolder.
