FireLite H365R Heat Detectors in Attic
I have no idea why I did this, but I put H365Rs in an attic. I have a FireLite ES-50X system in a garage, but when I got the parts and materials, I got H365Rs. They are rate-of-rise detectors, but looking at the datasheet, I guess they still go off at 135 degrees. Should I switch them out to be H365HT/H355HTs?
That might be a wise idea given how hot most attics get (especially during summertime): leaving the existing 135 degree heats in place may result in a false alarm one day.
Is the attic space climate controlled? If not, will the attic reach below 32° in winter? If, yes you shouldn’t use any addressable detectors. If no, yeah switch those out to H365HT. Dont use H355HT those are discontinued and only needed if using clip protocol panels.
Update: I actually have two replacement for those two H365R heat detectors, they are System Sensor 5602 heat detectors. They will be individually monitored by MMF-301 mini modules because I don’t feel like rewiring that part of they system. But the only problem now is I can’t get up there to install them because I have a broken foot… ouch.
