Fuse for old Edwards Panel?
So I’m looking to get this panel:
But I noticed there is a fuse missing on the panel. Is there any place that I could get a replacement fuse for it, or would it be ear impossible? Other than that I didn’t notice anything else missing/broken.
I am going out on a limb just a little, but it LOOKS LIKE it takes a 3.2 amp Fustat. This is similar to some fuses used on old Simplex power supplies used with 4208 systems. There was a 2001 power supply that used a Fustat also.
These are type S fuses that use a different thread pitch for each amperage of fuses so they can’t be interchanged. A 10 amp can’t screw into a socket meant for a 3.2 amp or a 30 amp can’t screw into a socket meant for a 10 amp fuse.
I found this source for these fuses.
Contact the seller and work out a deal that you will buy a fuse then send it to him. Tell him you will buy the panel if the fuse fits. He has to agree to hold the panel until he receives the fuse. That may require him to remove the listing, but he can relist if the fuse doesn’t fit. If the fuse doesn’t fit you are only out the cost of the fuse and not the cost of the panel.
Thank you, the seller was kind enough to let me send it to him and see if it fits. I’m sure hoping it does! Either way, I might end up buying the panel, as you don’t often come across these types of panels anymore.
