I’m thinking of a theoretical system with Gentex LF sounders in bedrooms and commander 3s and 4s everywhere else. To sync the LF sounders I’d use a GTSM, and for the commanders I’d use an AVSM. The only problem is that the GTSM only does T4 iirc. If I sent the sync code from the AVSM to the GTSM would the LF sounders do T3 or would it just fry the module
Why would you use two different models of sync modules when you could just use one or the other?
So the LF sounder strobes could do T3 or T4
Then why not just use the one that can do both instead of both it & the one that can’t? (especially since I’m assuming that if you set the Commanders to continuous they’d be able to do temporal 4 as well)
