Hey
Can anyone help me out with comissioning a network with Gekko fire panels?
Recently we’ve installed 14 GFE Gekko fire panels each one with INT-TCP/IP V2 network card.
The topology is mesh network. The panels are connected in switches and these switches are configured in a VLAN (no firewall installed).
A Gekko panel has two ports connected via flat cable to the network cards. The channels works separetely as each one can be set with a communication protocol.
At this time I’m trying to communicate two panel each other connecting them through one manageable switch which have no blocking rules. The network cards were configured with respective IP address, mask and gateway and the Odissey protocol
The panels network addresses was already set, Channel 1 was set as NONE and Channel 2 as Odissey in both
There is no more details in manuals about additional settings. It seems so easy setup, but it doesn’t work!
Can someone add any “hidden information” necessary to comission the network?
