So i want to put a heat detector in my attic, but is there any way i can put an LED like on my ceiling to show when it’s activated? Since these are shorting type devices i really don’t know if this is possible. Any help on this?
Use a dual contact device. One contact for the IDC. Run a separate power circuit to use the second contact to operate an LED.
Could you provide a diagram because im confused…
This drawing was adapted from a System Sensor 5600 series installation instructions. The resistor has to be calculated to match the LED current rating and power supply voltage. Or use an LED indicator assembly with an internal resistor (example Simplex 2098-9808). Then the external resistor is not needed.
