I wanted to use my Motor Horn with one of my New/Old 4903-9101 but the 4903-9101 is 24V and the Motor Horn is 12V. The Manual says it can run on 24V but every time I try it on 24V it sounds a bit higher pitched compared to it on 12V.
That might have to do with being fed more amps at 24VDC than 12VDC (or maybe the voltage difference itself somehow).
I find it odd that according to the datasheet at least it’s 85dB at 6VDC, then 88dB at 12VDC, but then back down to 85dB at 24VDC: one would think that the decibel rating would go up as the voltage goes up.
Going by the data sheet powering it at any of the listed voltages should be fine: no idea how Amseco engineered their BZ-54-series motor horns to run on 6, 12, & 24VDC but they apparently did somehow!
It’s literally a brushed DC motor inside those things, it will spin faster when it gets more voltage. Motor horn is literal, there’s a motor in there that spins and smacks against the horn to make noise. Take the back off some day, you’re in for a surprise
Yep: apparently it wasn’t a very popular concept however seeing as how Amseco were really the only ones to try it. I’m not sure the back can be taken off these horns though (including without damaging the mechanism or the latter falling apart).
