Horn dBA rating?
Hi, I have some questions with regards to calculating number of required Horn in a space for notification.
  • Is there a standard Horn dBA value that people use for design, for example, can we assuming a horn would be rated for 85dBA (or a different number) at every 10ft?
  • I was looking at a Horn product from Microm and based on the data sheet, there are different dBA values given in the table. I believe US installation should be based on UL464 table, but I am not sure which sound pattern and volume I should be looking at to determine the rating. (https://mircom.com/wp-content/uploads/product_documents/CAT-5360_FH-400_Wall-Ceiling_Mount_Horns.pdf)
It is that or greater iirc. Some even get over 100 dBA.
