Not the Trim but i need to get the alarm off so i can access the little power thingy so i can test it to make sure it works
Can you send some photos of behind the device and what you want to remove?
If it is the metal mounting bracket on the back that has the terminals, it should slide off if the device if it is slid to the side.
Check under the Gentex logo to see if there is a tamper screw holding the device
Theres none
i just checked
Thanks
It just slid right off
