How rare are these? Simplex 4903-9256 110 Candela Selectable SmartSync Horn Strobe
And also, is the date code 2001 or 2005? I would think 2001 since it’s a 4903 but I just want to make sure on that too
I believe the 4903-9256 may still be in production. It is listed on this catalog on the “Retrofit Notification Appliance Reference” page, since it is meant to replace older 4903 mechanical horns. However, it is not listed on the 2025 catalog, despite the other 4903 retrofit horn strobes being listed.
Thank you! Never knew these were still in production. I only thought the ceiling mount models were in production still. Interesting
The QuickAlert/TrueAlert series released in 1999, and I think these retrofit horns may have actually been released slightly later. The 4901-9820 is the standard QuickAlert/TrueAlert horn, while the 4901-9821 is a rebranded Wheelock MT and the 4901-9822 is the retrofit horn that sounds similar to the TrueAlert.
Interesting, this might be an early model because of the date code, I can’t tell if it’s 2001 or 2005.
I suspect that it is 2001 based on the date codes in this post.
So yeah this is likely a very early model, it’s lower pitch than an average TrueAlert
https://youtu.be/9KMOUNio1gM?si=KOJIiYbGb50iiqp1 here’s a reference of what it sounds like
Not rare at all, pretty common
Thanks for the info. I’m a bit newer on fire alarm stuff, I’ve been into smoke alarms for years, just recently got into fire alarms
simplex truealert strobe i recently just got it
Your date code on that indicates it was manufactured March 29, 2007 if I remember correctly. The first two characters in the date code indicate the year, the next 3 indicate the day of the year (001-366), and the letter indicates a plant it was manufactured in.
