I’m in the progress of planning out a homemade panel and I was wondering how to make a code 3 generator, any schematics could help me thanks.
Are you making one with an Arduino? If so, it can be done.
I tried using Arduino by using tinkercad, but the alarm would toggle on and I had no way of turning it off
You would have use a set of individual loops for each task, which what I did. One loop would do the alarm for each zone, and another would do the reset loop. But I would use Arduino IDE software to program the Arduino board.
Example:
void loop() {
fireZones();
zonesupervision();
alarmsilencedFunc();
walkTestFunc();
panelReset();
powermon();
acknowledge();
void fireZones(){
// and so on.
But I would use a Mega2560 for this task if you’re gonna put an LCD and such.
But for coding, you may have to make a menu setup or use another arduino like a Nano to do the coding. But thats up to you.
An Uno would also be fine if you use an LCD because i2C LCDs only require 4 pins rather than the parallel LCDs.
