Idk what to use it for but I found it in my closet. If anyone is interested or know what to use it for feel free to respond.
Even though it’s red it’s not a fire alarm panel: as the label in the first photo says it’s a “jockey pump controller”, which according to Google is a fire pump control panel.
I see, I don’t exactly know what to use it for however lol
I would say see if you could hook it up to a small pump and test it. Like a small one from Harbor Freight.
It’s a jockey pump controller, used in larger sprinkler systems. You would usually have the main large fire pump, and then you have the jockey pump that maintains the pressure in the system. It keeps the main fire pump from starting off eveytime the system loses pressure, and to stop short cycling. But if the system drops enough, then the main fire pump kicks on.
