Im in search of a System 5000 or AM-2020 for a project.
It’ll be easier to build one than finding a complete unit for a decent price.
Just buy all of the parts and build one
The System 5000 will be easier to build than the AM2020, here’s the bare minimum parts for each:
Both panels use the MPS-24A power supply. You’ll also need the harnesses which can be a PITA to find.
System 5000
- CPU-5000
- At least 1 IZM-8
- Other cards are optional
AM2020
- CPU-2020
- ICA-4L (chassis)
- LIB-200, LIB-200A, or LIB-400
- (Optional) SIB-2048/SIB-NET for annunciators.
Thanks, is it possible to Network the System 5000?
No, the System 5000 does not support NOTI-FIRE-NET. However, you can connect it as a slave panel to a networkable panel using a NIB-96 card.
For example, you can use the NFS2-3030 for networking and have the System 5000 as a slave panel. The 3030 will see all of the 5000’s points as modules, and you can ack/silence/reset the 5000 from the 3030.
Ah, ok. Thanks for the info.
