Hi all,
I’ve got an MS9200UDLS rev B board with a steady SLC voltage of around 6.5 volts on both the A and B circuits, although there is no SLC short or ground fault troubles on the panel. I was wondering in the slim chance that anyone has repaired these boards before or seen this issue before, if there’s a specific component (like a voltage regulator) that could be faulty. The only two components that were visibly broken was the top-right relay and varistor – I replaced both but am still only getting like 6.5v. Or, on the off chance that someone has a schematic for the board let me know as well. Thanks
