Edwards Genesis High Candela Horn/Strobes
Wall output is 110, 135, 150 & 185CD
Ceiling output is 95, 115, 150 & 177CD
Edwards Genesis High Candela HF Speaker/Strobes
Edwards Genesis High Candela LF Sounder/Strobes
Wheelock MT-IS-24-HFW Horizontal Strobed MT
Wheelock ET1080-HS-24-CFW 110CD Speaker/Strobes Older vs Newer
Wheelock ET1080-HS-24 110CD Speaker/Strobes other models
Wheelock E-70-HS-24 & E-90-HS-24 110CD Speaker/Strobes late 1990’s
Wheelock ET-1070-HS-24 110CD Mid 1990’s Speaker/Strobes
Wheelock ET-1070-WM-24-HF-W Speaker/Strobe (Horizontal Strobe)
Siemens U-MHST High CD Horn/Strobe & S-HP High CD Speaker/Strobe (135, 150, 177, 185CD)
30CD System Sensor MASS models
30CD System Sensor SP1 Series ADA
Speaker/Strobe
Seriously, I want to find an SP1R24110ADA on eBay.
75CD & 110CD System Sensor MASS Synchronized Sounder/Strobes
4 Wire System Sensor SpectrAlert Advance LF Sounder!
A bunch more Simplex 4903 Speaker/Strobe Models OMFG
Red Vertical 25VRMS Free Run
Red Vertical 70VRMS Free Run
BTW, the 4903-9177 is 30CD.
Red Vertical 25VRMS Sync
Red Vertical 70VRMS Sync
White Horizontal 70VRMS Free Run
White Horizontal 25VRMS Sync
White Horizontal 70VRMS Sync
Simplex 4903-9144 & 4903-9174 Free Run 110CD Speaker/Strobes with older model number sticker because why not
These are two White Vertical SmartSync 110CD Speaker/Strobes
The 15CD models are 4903-9337 & 4903-9340
The 30CD models are 4903-9338 & 4903-9341
This is a Simplex 4903-9344; the White Counterpart of the 4903-9153
This is a Simplex 4903-9349 which is a Red Version of a 4903-9198. Not a ‘True’ Alert
4904-9325; this is a SmartSync 15CD Strobe
This is a 4903-9262; a ceiling mounted counterpart of both the 4903-9219 & 4903-9220 15CD Electromechanical Horn/Strobes
A few added Simplex 4904 SmartSync Strobes
Red Wall Vertical:
Red Ceiling:
Red Wall Horizontal:
4 Wire Ceiling Mount TrueAlert/QuickAlert Horn/Strobes
SmartSync TrueAlerts predating the 4906-9128 & 4906-9130 be like
Let’s fill in the White 70VRMS Speaker/Strobes
Perfect! Makes complete sense!
Some Red Vertical Mounted 70VRMS Speaker/Strobes!
The ‘True’ Alert Ceiling Speaker/Strobes
Additional 2902 Speaker/Lights alongside from the 2902-9735
Additional 2902 Speaker/Strobes alongside the 2902-9739
SmartSync Fixed CD TrueAlert Ceiling Strobes before 4906-9102 & 4906-9104
Other 4904 White Free Run Strobes alongside 4904-9138
TrueAlert Free Run Ceiling Strobes
The 2902-9733; a 70VRMS Counterpart to a 2902-9732
That makes perfect logical sense!
Other Red Vertical mounted selectable Speaker/Strobes alongside 4903-9153
These ones are spaced out too much ugh…
Wheelock AS & MT Additional Horn/Strobes be like
Let’s customize the MT & AS Horn/Strobes COMPLETELY!
EST Genesis High Fidelity & High Candela (110, 135, 150 & 185CD) Speaker/Strobes
Really EST, you weren’t customizable enough
Added 4903 Models be like
Sync Red Ceiling 30CD Electromechanical Horn/Strobe:
Sync Red Ceiling 15CD Electromechanical Horn/Strobe:
Sync Red Ceiling 110CD Electromechanical Horn/Strobe:
Sync White Ceiling 15CD Electromechanical Horn/Strobe:
Sync White Ceiling 30CD Electromechanical Horn/Strobe:
Sync White Ceiling 110CD Electromechanical Horn/Strobe:
Sync Red Vertical 15CD Electronic Horn/Strobe:
Sync Red Vertical 30CD Electronic Horn/Strobe:
Sync Red Vertical 110CD Electronic Horn/Strobe:
Sync White Vertical 15CD Electronic Horn/Strobe:
Sync White Vertical 30CD Electronic Horn/Strobe:
Sync White Vertical 110CD Electronic Horn/Strobe:
Sync Red Ceiling 15CD Electronic Horn/Strobe:
Sync Red Ceiling 30CD Electronic Horn/Strobe:
Sync Red Ceiling 110CD Electronic Horn/Strobe:
Sync White Ceiling 15CD Electronic Horn/Strobe:
Sync White Ceiling 30CD Electronic Horn/Strobe:
Sync White Horizontal 30CD Electronic Horn/Strobe:
Sync White Horizontal 15CD Electronic Horn/Strobe:
Sync White Ceiling 110CD Electronic Horn/Strobe:
Free Run White Ceiling 15CD Electronic Horn/Strobe:
Free Run Red Ceiling 110CD Electronic Horn/Strobe:
Free Run Red Ceiling 30CD Electronic Horn/Strobe:
Free Run Red Ceiling 15CD Electronic Horn/Strobe:
Sync White Horizontal 110CD Electronic Horn/Strobe:
Free Run White Ceiling 30CD Electronic Horn/Strobe:
Free Run White Ceiling 110CD Electronic Horn/Strobe:
Free Run Red Ceiling 15CD Electromechanical Horn/Strobe:
Free Run Red Ceiling 30CD Electromechanical Horn/Strobe:
Free Run White Ceiling 30CD Electromechanical Horn/Strobe:
Free Run White Ceiling 15CD Electromechanical Horn/Strobe:
Free Run Red Ceiling 110CD Electromechanical Horn/Strobe:
Free Run White Ceiling 110CD Electromechanical Horn/Strobe:
Free Run White Vertical 15CD Electromechanical Horn/Strobe:
Free Run White Vertical 15CD Electronic Horn/Strobe:
Free Run White Vertical 110CD Electromechanical Horn/Strobe:
Free Run White Vertical 30CD Electromechanical Horn/Strobe:
Free Run White Vertical 110CD Electronic Horn/Strobe:
Ever heard of a model number called Simplex 4903-9205? It’s the vertical mounted version of the 4903-9202 predating the 4903-9218!
How bout’ 4903-9208? This is a White version of the -9202! This is what they used before the -9223!
The Ceiling mounted versions are called 4903-9211 & 4903-9214
Simplex 4904-9110; The 15CD 24FPM Strobe (The early version of the 4904-9137)
Simplex 4904-9111; The 30CD 24FPM Strobe (The early version of the 4904-9135)
The 4904-9136 replaced the 4904-9112 obviously as both are 110CD
If Simplex made 24FPM strobes in a White Housing model numbers might’ve been
4904-9113 (15CD); Pre 4904-9138
4904-9114 (30CD); Pre 4904-9141
4904-9115 (110CD); Pre 4904-9144
Since 4904-9121 is an earlier model of the 4904-9145 these are the earlier models of the 4904-9139 & 4904-9142 strobes
4904-9119 predated the 4904-9139
4904-9120 predated the 4904-9142
Ay Simplex! “Yeah?” Make a 110CD White blank Ceiling Strobe!
Simplex White 110CD Electronic Horn/Strobes be like
Hey, have you heard of an Edwards Fixed Candela Genesis Speaker/Strobe? They were manufactured from 2000-2002!
30 & 30/75CD Pyrotronics F-Series Be Like
Faraday’s 110CD Synchronized F-Series Strobe
Did you ever hear Gentex made different Candela options for the G4 for Simplex plates
High Candela Wall Mount Edwards Genesis be like
Multi Tone Edwards Genesis?!
The Multi Tone Integrity
If Edwards still made a 60CD Xenon Genesis until discontinuation date
30/150CD Genesis twice as bright as the G1RF-HDV1575
Edwards 2A Integrity Model Number
Edwards 9A Integrity Model Number
Syncable version of the MT-24-IS
Mid 1990’s to Early 2000’s 110CD Unsynchronized Wheelock MT Model Number be like
Mid 1990’s to Early 2000’s 110CD Synchronized Wheelock MT Model Number be like
30/110CD Wheelock AS?!?! This should’ve been a thing
Wheelock MT with 30/110CD Unsynchronized Strobe
Wheelock MT with 30/110CD Sync Strobe (Red for 30/110 & Green for 15/75)
The synchronized 30CD strobe Wheelock MT
Wheelock AS 30/110CD Vertical Strobe not sync capable
Wheelock AS 30/110CD Vertical Strobe Sync capable
SR-2475 the sync version to the RS-2475
4 Wire Wheelock Exceeders be like
Alright this is another made up fire alarm. I am well aware that this does fit the made up fire alarm topic but I’ll just put it here for now.
This is a Simplex 4903-9442, which is a ceiling mounted 110CD SmartSync Horn/Strobe
This is obviously a QuickAlert ceiling mount which would have the same strobe reflectors as the ones that have the TrueAlert marking however the backs are different. The QuickAlert ceiling models had no hole on the back which would mean you’d have to wiggle the strobe in order to change the settings. The TrueAlert models did have that hole on the back. This would have applied to a model that predated the 4906-9128 alongside the 4903-9440 & 4903-9441.
4903-9177; 70VRMS Red Vertical Mounted Free Run 30CD Speaker/Strobe!
Genesis HV Horn/Strobe 110CD
Come on Edwards don’t be lazy. You’re kind of losing your mind here
Anyone seen a Simplex 4903-9142 with an older model number sticker from 1997? Not me. I bet models with this date code have a blue circle sticker on the strobe reflector
The Simplex 4903-9144 from 1997 that does not have a candela sticker
Edwards G4RF-S7VMH High Intensity Genesis Speaker/Strobe
Edwards G4F-S7VMH High Intensity Genesis Speaker/Strobe
Simplex 4904-9188; This is a White Horizontal 110CD Selectable Free Run & Sync Strobe
Simplex 4904-9146; The White Horizontal 110CD Free Run Strobe
Simplex 4904-9140; The White Horizontal 15CD Free Run Strobe
