Redwood High School (Built 1979)
Original building has an old Fire-Lite C-Series panel with BG-6 Pulls and Wheelock 34-24 horns completely flush mounted flat in the walls set to continuous. The building has no smoke detectors only heats.
Building Annex (2004)
Fire-Lite MS-5UD was added to the Annex tied to the original system with Wheelock MT-24-LSM horn strobes set on Code 3 tone and BG-10L pull stations. It has System Sensor 2100 Smokes and a few System Sensor heat detectors.
New Gym Not Attached To Building (2019)
Devices were run by the MS-5UD in the annex part and set all 3 systems off. The gym has Wheelock Eluxa horn strobes on code 3 and BG-12L pull stations. It has System Sensor i3 smokes. No heat detectors.
