Make Up a System (2.0)
A school was built as a new middle school to replace and old aging middle school called the Cutler Middle School with a system that was installed and modified over time like this.
[quote] The hallways of the school and other areas not mentioned all have Wheelock 7001T horn/strobes
The largest music classroom in the school, the health classroom and the administration hallways have Wheelock 34T horn on a Space Age Electronics AV32 light plate that stays lit up.
The only courtyard that is accessible to go out and have classes in, the main entrance and the stage in the gymnasium have Wheelock 7002 horn/strobes.
Both locker rooms in the school and the resource room have Gentex GMS horn/strobes.
The media center and the back exterior of the school have vertical Wheelock AS horn/strobes.
The largest science classroom has a Simplex TrueAlert.
Here’s a middle school system. I’m too lazy to come up with a name for it.
The school was built in 1926, obviously with no real fire alarm system, just a few hand-operated bells to alert in the event of emergency.
At some point in the 1940s, an Autocall “pull rod” fire alarm system was added throughout the main level of the school (there were three floors in all, with no elevator… more on that later). 10" Autocall single-stroke bells were added, three in each of the three hallways, plus one in what was at the time a general cafeteria/multipurpose room/gymnasium, for a total of ten bells.
Fast forward to the late 1960s, amazingly the Autocall system has done it’s job incredibly well, but in 1968, the school realized there were issues with students on the second and third floors being unable to hear the bells. Because of this, along with an upcoming addition of a new cafeteria and gymnasium, plus the renovation of most classrooms, the entire Autocall system was replaced with a Simplex system, with new Simplex 4037 horns being installed in each hallway, plus two in the new gymnasium, one in the new cafeteria, and one in the renovated multipurpose room. In addition, Simplex 4263-1 pull stations were installed (two in each hallway, two in the gymnasium, one in the cafeteria).
Throughout the 1970s, little changed with the fire alarm system. In 1979, a 4263-1 in a hallway was found to be defective. It was replaced with a Simplex 4251-30 pull station.
Similarly, in 1981, a second pull station broke, also to be replaced by a Simplex 4251-30. Three years later, a Simplex 4037 in the gymnasium broke, and was replaced by a Simplex 2901-9806 horn. In 1989, a new special education wing was added, with Simplex 2901-9838 horns on 2903-9101 strobe plates. The classrooms in this wing all received Simplex 2904 strobes as well. In addition, a Single 4037 installed in the ground-floor hallway next to the special education wing had to be removed during construction, and was replaced with another 9838/9101 combo about 10 feet further down the hall. A Simplex 4004 replaced the older Simplex panel to handle the larger system.
Following an exciting 1980s fire alarm-wise, not much with the system changed into the 1990s. The 1960s Simplex system was still largely intact in the main building. In 1995, both of the band/orchestra rooms recieved Simplex 4903-9219 horn/strobes. Another -9219 was also installed in the gym, ironically not replacing the remaining Simplex 4037, but instead the -9806 that was barely ten years old. In 1998, the district ended its longtime partnership with Simplex, and instead began utilizing a Gamewell distributer.
In 1999, it was found that the school, largely unchanged since the 1968 renovation, was in despite need of repair. There were nowhere near enough classrooms, no elevator, out-of-date science labs, no true computer labs, and a kitchen that was full of code violations. Obviously, this meant it was time for a renovation, planned to take place in stages from 2000-2002. In addition, the district managed to secure additional funds to build an auxiliary building, which would include a gym, a pool, a media center, two gymnasiums, a gymnastics room, a new front office, a new cafeteria, and a student center. This building would connect to the existing one via two elevated skyways (sort of going off of a real school in my area for this one). It was decided that the existing gymnasium and cafeteria would be converted into additional classrooms, as opposed to adding a new wing with classrooms onto the back of the school. In other news, despite the fact that everything would be ripped out the following year, a broken Simplex 4037 was replaced with a Gamewell/Wheelock AS.
In June, 2000, work began on the $53 million project that would add twelve new classrooms, an entire new 58,000 square-foor building, and remodel the entire school from top to bottom began. Midway through the planning process the district decided to move all students to another closed school nearby for one year due to safety reasons. However, this meant that the project would largely be complete by fall 2001, as opposed to fall 2002, and would also save the district a bit of money. Back to the fire alarms…
The system chosen for this project was a massive Gamewell addressable system. Throughout the entire school, Gamewell Century dual-action pull stations would be installed. In the main building, the notification appliance of choice happened to be Wheelock NS horn/strobes, with Wheelock RSS strobes in most classrooms. For some bizarre reason, likely due to an ordering mix-up, a Single Wheelock ASWP was installed in one of the hallways. In the auxiliary building, Wheelock E-70 and E-90 speaker/strobes were chosen. This building also has Gamewell Century pull stations.
Since then, the only changes have been a few pull station spot replacements (all with Gamewell-branded BG-12s), a few notification appliance spot replacements in the main building (depending on when, either NS’s, ZNS’s, or Exceder-series devices). In 2017, the student center was renovated and expanded, and Wheelock LED Exceder ceiling-mount speaker/strobes were installed. This is how the system remains as of January 2018.
OK here I have a school that is slightly smaller and doesn’t have a whole lot of repeating alarms except for the hallway alarms but when alarms did get replaced at different points, they always almost used a different company for a new alarm that they needed.
This is how the Wayzata Elementary School is set up.
[quote] Edwards 792 horn/strobes are set up in all areas not mentioned (not that there are a lot) as well as all the hallways
A Gentex GMS is to the left of the doorway above the whiteboard in the music classroom
A Simplex 2901-9833 on a 2903 strobe plate is the alarm in the special day classroom for grades PK to 2 right next to the restroom in there
There is a Wheelock 7002T in the art classroom mounted next to the kiln room in there
Next there is a SpectrAlert Classic in the nurse’s office on the back of the side restroom wall
Finally, next to the doorway in the Bright Start classroom, there is an Edwards Genesis horn/strobe
i dont mind :lol:
This is a school that is a bit bigger than the last one because its a K–8 school so it has 2 more grades than other elementary schools which would go up to 6th and send 7th to the middle school but this school had an addition put on it so it could fit 2 more grades than the other elementary schools and this is the way the system is set up.
[quote] All hallways and areas that aren't mentioned have Simplex 2901-9833 horns on Simplex 2903-9101 light plates which stay lit up when the system goes into alarm
Both the multipurpose room and the elementary art classroom have Faraday 6120 horn/strobes
The enclosed courtyard, the technology classroom and the middle school addition all have Siemens U-HNH horn/strobes
The band classroom has a Gentex GX-90 horn/strobe
While the elementary music classroom has a Simplex TrueAlert
Finally the science classroom and the elementary media center each have Simplex 4051 horns on Simplex 4050-80 light plates which also stay lit up when the system is in alarm
Maybe the next system will have Simplex 4903-9219s again or a Wheelock AS.
A 3 story home, built in 1955, originally had an IBM 4201-2 fire alarm system. The signals were mostly IBM 6-Inch Single Stroke bells, one on each floor. Bellow each bell was an IBM Chevron Pull Station. Chemitronics heat detectors were installed on each stairwell landing. Signal coding is 17-0-0.
In 1982, a bell on the first floor was found dead, it was replaced with a Simplex 2901-9361 Single Stroke Bell.
In 1989, an IBM Chevron was found inoperative and was replaced with a Simplex 4521-20.
In 1992, the IBM panel was struck by lightning. It was replaced with a Simplex 4002. They also put Simplex rebranded Gentex GX-90 Horn/Strobes in each bedroom, and GX-90 Horns in the bathrooms and laundry room. Simplex “Wiffleball” smokes are installed in each bedroom, and an ESL heat detector was installed in the laundry room. A Simplex 2099 was installed in the garage, as was a Simplex 2901-9846+4903. Signal coding was fast march time. Everything else, including the original IBM pulls and bells remained.
In 1995, they renovated two rooms into a home theater room, one room became the lobby/concession stand, the other became the actual theater itself. They put in 3 Simplex 4903-9217 Horn/Strobes (one in the lobby, two in the theater itself). A 4099 pull station and a TrueAlarm Smoke are also installed.
In 1997, a wiffleball smoke failed and was replaced with a Simplex TrueAlarm Smoke.
In 2005, a GX-90 horn/strobe in one bedroom failed and was replaced with an EST Genesis Horn/Strobe.
In 2006, a GX-90 horn in the middle floor bathroom was found inoperative and was replaced with a Wheelock ZNS Horn/Strobe.
In 2009, the fire alarm system was upgraded. The 4002 and all its components were removed. The new system is an Edwards EST3. Signals are mostly Genesis Horn/Strobes and Strobes, with the home theater room gaining five EST Genesis Speaker/Strobes (one in the lobby, four in the theater itself), and a EST Integrity Horn/Strobe was installed in the garage. Pull stations are mostly EST SIGA 278 and there are EST SIGA Smokes installed throughout. Signal coding is Code-3, with Speaker/Strobes playing a Slow Whoop tone and voice message.
BTW, the Simplex 4903’s are now nicknamed “VHS tape”.
The previous school before was called the Weddington Elementary/Middle School. This school which houses 1200 students is just a middle school, named the Seymour A. Louis Middle School. The system is set up thusly.
[quote] In most of the school, the alarms that they have are Edwards 792 horn/strobes
The Fire Sciences classroom (an elective class) has an older Edwards 895B-001 horn/strobe
The Wood Shop, Drama and Photography classrooms (another elective) have Simplex 4903-9219 horn/strobes
Both the Home Economics Kitchen and the STEM lab have Wheelock 7001 horn/strobes
The music classroom has an Edwards Genesis
Finally the Media Center has a Cerberus Pyrotronics MTL-S15-S horn/strobe set to code-3 bell
Next school might have more 792s and an AS.
there are large houses with fire alarm systems? Or was this just you?
GEEZ, how big was this theatre? My SCHOOL’S auditorium doesn’t even have four notification appliances :shock: :lol: .
My school’s auditorium is HUGE and it only has horn/strobes, yeah I just noticed that part. Is this a mansion?
This is the story of the Apex Friendship High School.
[quote] The alarms in most of the school are Edwards 792 horn/strobes
The music classroom has an older Edwards 892-2B horn/strobe
The electrical shop and drama classroom both have Edwards Adaptahorn (model 881D) on Edwards 891D light plates which have fire lettering on the lens and flash in march time
Since there were two separate buildings, the walkway between them that was built was renovated and received Faraday U-HNH horn/strobes as well as the ESL room
Over in the computer technology classroom weight training room, the alarms are System Sensor MASS241575ADA on 1200 Hz continuous but coded in temporal from the panel
Finally the ceramics lab and the print making lab both have Wheelock Exceeders
Now we can do a school with AS’s.
The home theater is about 3456 cubic meters. So basically a large room.
Here’s another one.
A one-story single family house, built in 2002, originally had a Notifier AFP-200 Fire Alarm System. Signals were mostly red Wheelock NS Horn/Strobes. These were installed in the hallways, living room, dining rooms, kitchen, bonus room, master bath, and laundry room. White Wheelock NH Horns are installed, ceiling mounted, in bedrooms, and the bathroom. The garage has a Wheelock AHWP horn, and the patio has a Wheelock ASWP Horn/Strobe. Pull stations are mostly Notifier BG-10s, and there are System Sensor 2400 smokes installed in each sleeping area and in the hallways. Signal coding was code 3.
A swimming pool with deck was added in 2003, so they added two Wheelock AHWP Horns and RSG Weatherproof T-Bars. Nothing else was changed.
In 2005, a Wheelock NS broke and was replaced with a SpectrAlert Classic Horn/Strobe.
In 2006, two BG-10s were replaced with BG-12s.
In 2009, a second story was added on. With that brought a train layout room, storage closet, repair shop room, home theater room (and lobby), a new restroom, and a new attic. A Notifier NFS2-640 w/ DVC is installed and both the AFP-200 and NFS2-640 monitor one another. The signals are Wheelock HSR Horn/Strobes, with Wheelock STR strobes added where strobe coverage was needed. Wheelock E70 Speaker/Strobes are installed in the home theater room and lobby. Pull stations are Notifier BG-12LX and Notifier FSP smokes are installed as well. An ESL heat detector was installed in the repair shop and attic. Also during this time, a BG-10 broke and was replaced with an Edwards 270-SPO.
In 2013, the AFP-200 died. It was gutted/converted into a terminal cabinet and the NFS2-640 now monitors the entire house. The BG-10s and 270-SPO were replaced with BG-12s and the System Sensor 2400 smokes were replaced with Notifier FSP smokes. Signals mostly remained the same.
This school is a 2000 student high school which houses grades 9 to 12 and has a very unique mix of alarms.
[quote] In most of the school, the alarms are a mix of newer and older Gentex SHGs but there are more older SHGs
Located in the graphic design lab and the HVAC shop are Federal Signal 450D horns with VALS strobes
Three rooms, which are the business technology lab, the drama classroom and the computer technology lab have Faraday 5640 horns behind Faraday 5415 light plates that blink in march time
Over in the carpentry lab and the weight room, the alarms are Amseco BZ-50Ps behind Amseco SB24 series Select-a-Strobes
The band room has an Edwards Genesis
Finally, the health classroom and machine technology lab have Wheelock ASs.
In 2000, a two-story home was built. The original system was a Notifier SFP-400 with BG-10L’s by each exit, System Sensor conventional smoke detectors, and an annunciator by the front door. It had Wheelock AS horn/strobes in every room. The system worked perfectly until a remodel.
In 2010, the house was remodeled. The old panel was removed and replaced with a Fire-Lite MS-9200UDLS, pull stations were replaced with BG-12LX’s, smoke detectors were replaced with System Sensor addressable multi-criteria smoke detectors, and a Wheelock SPMNS system was added. Horn/strobes were replaced by System Sensor SPSCW-P’s and SPSW-P’s for ceiling and wall. The system also got custom tornado warning alarms and CO alarms. During the remodel, the homeowners opted to add a water sprinkler system with flush heads and a duct detector.
In 2016 one SPSCW-P broke and was replaced with an SPSCR. Later that year a pull station cracked and was replaced.
In 2017 the old owners moved and the house got new owners. They decided to remove all the pull stations and annunciator since they thought it was excessive.
Pretty basic system but still something nonetheless.
This is the current system of Dixon Middle School.
[quote] In most of the school, the alarms are Wheelock 7002T horn/strobes
Located in the engineering and agriculture labs are Wheelock 34T horns on Space Age Electronic AV32 light plates that blink in march time
One room, the art room, has a Faraday U-HNH
Over in the keyboarding classroom, the alarm there is a Fire Lite 450 horn on a Simplex 4050-80 light plate with white “FIRE” lettering that stays lit up when the system goes into alarm
The band room has a Mircom FHS-340 set to code-3
Finally the life skills lab has a SpectrAlert Advance set to code-3
Middleton Public Library, built in 1988, originally had a Simplex 2120 Fire Alarm System. Signals were for the most part Simplex 2901-9711 Speakers on 2903 Strobe Plates. Restrooms had 2904 Remote strobes. They also put Simplex Bullseye Speakers on the exterior in the back courtyard. Pulls were Simplex 4521-20s and there were Simplex wiffle-ball smokes installed throughout. ESL Smokes are installed at each elevator landing for elevator recall. The speakers play a whoop tone similar to this: https://www.youtube.com/watch?v=aAZ49zcCcO4
A Wheelock 7004T is installed outside to serve as a Sprinkler Alarm.
In 1990, a Simplex 4521-20 within the Genealogy Department failed and was replaced with a Simplex 4099.
In 1992, a Coffee Shop/Bistro was added on. They put 2 Simplex 2902-9732+4903 Speaker/Strobes in the new coffee shop along with a Simplex 4099 and two Simplex rebranded ESL smokes. They tied the coffee shop into the 2120.
In 1995, a Simplex 2901-9711 died and was replaced with a Wheelock E70 speaker. Also a 2903 broke and both the speaker and the strobe plate was replaced with a Simplex 4903 Speaker/Strobe.
In 1997, two Wiffle-ball smokes died and were replaced with Simplex TrueAlarms.
In 1999, staff complained that the alarm could not be heard in the study room, so they added Wheelock MIZ Horns into the study rooms.
In 2003, a LifeAlarm Speaker in the youth department was found inoperative and was replaced with a Simplex TrueAlert Speaker. Also a Simplex 2099 replaced a 4521-20.
In 2009, a 2904 in the first floor mens room died and was replaced with a Wheelock RSS Strobe.
In 2011, they renovated the library. A new Simplex 4100U replaced the 2120. The new signals are Simplex TrueAlert Speaker/Strobes, with Simplex TrueAlert Remote Strobes to add additional strobe coverage where none was previously provided. Outside they put Wheelock E70WP speaker/strobes. Pulls are Simplex 2099s, and they installed new Simplex TrueAlarm Smokes throughout. Speakers now play a Slow Whoop tone and a voice message.
This is the current system of an urban high school which has 1600 students in total from grades 9 to 12 attending here and has a 3 story tower which is attached to the main 1-story building through some walkways.
[quote] In most of the school, the alarms are Simplex 2901-9838 horns on Simplex 4903-9101 strobe plates
Located in the weight room and early education and care vocation lab are Simplex 2901-9806 horns on Simplex 2903-9101 strobe plates
Two rooms, the in-school suspension room and the exceptional children room have Simplex 4903-9217 horn/strobes
Over in the walkway that connects the tower to the main building, the band room and the precision machining vocational lab, the alarms are Simplex 4903-9236 horn/strobes
The environmental and biotechnology vocation lab have Edwards Genesis in code-3
Finally music classroom, computer and engineering vocational lab and legal and protective services vocational lab have a Wheelock 34T on Space Age Electronic AV32 light plates that blink in march time
WoodDale Apartments, built in 1988, originally had a Simplex 4001 Fire Alarm System. Signals were mostly Simplex 2901-9838 horns. A couple were put on Simplex 4903 Strobe Plates. Individual apartments had Wheelock EH-EL1 Horns. Pull stations were Simplex 4521-20s. As for smokes, each apartment had Simplex 2098-9642 smokes in addition to a BRK hardwire smoke detector, and in the enclosed corridors, they put Simplex heat detectors. Signal coding was continuous.
In 1992, a 2901-9838 died and was replaced with a Gentex GMH Horn.
In 1995, two Simplex 2098-9642s failed and were replaced with older TrueAlarms.
In 1996, a EH-EL1 Broke and was replaced with a Wheelock MT-24LSM Horn/Strobe.
In 1998, a 4521-20 was found inoperative during an inspection and was replaced with a Simplex 4099.
Between 2002 and 2005 a number of EH-EL1 Horns broke, they were replaced with Wheelock NS Horn/Strobes. Also in 2004, a 2901-9838 died and was replaced with a Wheelock AHWP Horn.
In 2006, a Simplex 4903+2901-9838 was found inoperative and was replaced with a System Sensor P2RW Horn/Strobe.
In 2007, a 2098-9642 broke and was replaced with a Simplex TrueAlarm. Also a heat detector was replaced with an ESL Heat Detector.
In 2009, a 2901-9838 died and was replaced with a Simplex TrueAlert Horn.
In 2011, two 4521-20s failed and were replaced with Edwards 270-SPOs.
In 2013, the fire alarm panel was damaged by a lightning strike. The panel was replaced with a Simplex 4006. Everything stayed the same.
In 2015, a number of Simplex 2098-9642 smokes were found to be inoperative, and were replaced with TrueAlarm smokes. Also all the older BRK smokes were removed, as they installed TrueAlarm smokes into each bedroom with built in sounders.
In 2016, a 2901-9838 Horn died and was replaced with a Wheelock AS Horn/Strobe.
In 2017, a Sprinkler System was put in and tied into the Simplex 4006. They put a Federal Signal 350+VALS Horn/Strobe to act as a Sprinkler Alarm.
