Well for some reason that I don’t know of, my post about the previous school ended up getting the majority cut off and I have no idea why the heck that happened. I just noticed it now and I can’t edit it. Its fine, but just to remind myself, that school there was the E.D. Smith elementary school which serves grades Preschool through 6th grade. This is the final middle school of the Oakwood City school district. But this is the setup of Liberty middle school when it comes to the system.
[quote]
Like the other schools, this school has Faraday 5640 horns on 5415 flashers
The chorus classroom has a Simplex 2901-9806 horn on a 2903-9101 flasher
The weight room has a Siemens U-HNH horn/strobe
The family and consumer science kitchen has an Amseco BZ-54VT with a RSD-24L strobe attached
The nurse’s office has a Siemens U-MMT horn/strobe
Ash Trash Plant is a 2 story trash dump built originally in 1989. In 1994 a new addition was built to add more offices and trash processing. In 2009 a renovation replaced the chillers and repaired some parts of the 1990’s addition. In 2012 a renovation replaced some HVAC equipment.
Panel:
Current: Notifier ONYX NFS2-640 Fire alarm panel and voice evacuation system
Original: Simplex 4002
Initiating devices:
Current: NBG-12-LXs and Notifier Smoke/Heat combos
Original: Simplex 4251-20 t bars and older truealarm smokes
Notification appliances:
Current: System Sensor L series Speaker/Strobes
Original: Simplex 2901-9833s installed on Simplex 4903-9105 light plates
Sprinkler system:
Grinnell Sprinkler riser installed in 1996
Potter VSR Retard flowswitch
Potter INS-500 Nitrogen generator
PFC-6006 Fire sprinkler panel
Potter MBA bell connected to Wheelock LSM non ADA strobe outside
HP Industries (A company that manufactured animatronics for the entertainment business) owned there main manufacturing plant from 1952 until 1998 due to safety violations. The system is a retrofit of a Standard Electric Time Panel system and a late 80’s simplex system.
Panel:
Standard Electric Time coded panel with code 4-4-4-4 code wheel
Simplex 4002
Simplex 2001 repack
(All panels are linked)
Faraday Type 2 projector horns
All simplex panels are connected to Simplex 4050s on 4050-80s.
Initiating devices:
Standard “round” stations
Simplex 4251-20s
Smiley Face Elementary School is a 2 story school built in 1987 and is connected to Smiley Face Middle School (One of my older posts on this discussion. Smiley Face Middle was Built in 1975.) The School was part of Davidson County until 1998 when Cumber County expanded and got the school in the expansion.
Panel:
Simplex 4100ES monitoring the 1987 classes, cafeteria and the basement
Simplex 4006 monitoring 1998 gym and auditorium
Simplex 4003EC connected to 4006 in auditorium
Initiating devices:
Simplex Truealarms on all panels
Simplex ADA t bars on all panels
Simplex Truealert ES devices installed in halls, gym, cafeteria, and basement
Truealert ES strobes in bathrooms, classrooms and the closets
Truealert ES mini horns in some closets
Simplex ES speaker/strobes in the auditorium
Simplex Time Recorder Bell outside cafeteria
Clock/Intercom:
Simplex clock/intercom combos
Rauland call buttons in most rooms except closets and restrooms
Rauland-Borg telecenter ICS
Simplex 4" bells for school bells
Suppression system in cafeteria:
Pyro-chem control head and tank
Unbranded control box
Wheelock 34t horn
Wheelock “HALON” strobe (non ADA)
Suppression system in science classes:
Simplex 4004R suppression panel
Simplex 4" bells
Wheelock MTs set on siren
Siemens agent release stations
Simplex 2901-9838
Simplex remote strobes in restrooms and closets
A Wheelock NS was installed in the manager’s office
A Wheelock AS was installed in the loading bay
A Wheelock MT was installed in the furnace room
ABC thrift store is a 1 story thrift store in a shopping complex. The complex was originally built in 1979. The stores in there were: Ash Dry cleaning, Dan’s Grocery, Sallie pool supplies, The west bar and the thrift store. Most of the stores are closing. The thrift store, Dan’s Grocery and Ash Dry cleaning.
Panel:
Radionics D7022 Fire alarm panel
Initiating devices:
Radionics smokes and heats
Radionics RSG-RMS-1TKLs
Oak High School is a high school originally built in 1992. The school has 7 halls (excluding staff only halls.), 2 boiler rooms, a gym, a cafeteria, 103 class rooms, A 300 square foot media center and computer lab hybrid, 2 science labs, 7 portables outside, A auditorium, A basement and a large tunnel system under the school connected to the the basement and service building.
Panel:
Simplex 4100ES in electrical room in the main office. Remote command center in auditorium.
Initiating devices:
Simplex ADA T bars
Simplex TrueAlarms
Simplex duct detectors
Simplex ES speaker/strobes in most areas including classes and auditorium
Simplex Truealert ES horn/strobes in gym.
Wheelock MB-10 10 inch motor bells outside gym
Wheelock MB-4 4 inch bells outside auditorium
Simplex ES speakers in tunnels and basement
Federal Signal 350 Gray horn in panel control room. 3 buzzes in a row signals supervisory. 1 loud buzz signals fire alarm. code 4-4-4-4 signals a trouble. 5-6-4-3 signals power failure.
Clocks & intercom systems
Simplex wired clock system
Simplex 4 inch bells for passing classes and for all clear in case of a fire drill, lockdown, tornado, earthquake or chemical drill.
Simplex intercom system
Suppression:
Science rooms all have Fenwell halon control system
Ansul halon tanks
Fenwell halon MT set on bell
Fenwell RSS
System sensor MASS White horn only
Sprinklers:
Grinnell sprinkler system
Potter PBA and MBA bell outside riser room. MBA bell signals riser failure. PBA Bell signals fire sprinkler activation
Other signaling:
Adaptabell installed on sewage pump
Simplex 10" bell connected to sewage
Wheelock MT white horn only devices outside set on bell and whoop for class changing because there are no bells outside.
Federal signal beacons outside for lockdowns (blue)
STI Stopper stations for tornado and lockdown emergencys
Federal signal selectones for lockdown and tornado. All set on siren
Tornado siren:
ACA Allertor installed outside the school (It was installed in 1978 WAY before the school was built.) due to the school being in the middle of of tornado alley.
Caribou Community K-8 school is an elementary-middle school that has a mostly Gentex system with mostly Gentex notification appliances except where otherwise stated.
Gentex SHG
In hallways and other areas not noted
Edwards Adaptahorn+802-2B
Larger STEM lab, multi-purpose room and ESL classroom
Wheelock 34-24+Space Age Electronics AV32
Art classroom and computer lab
Simplex 2901-9806+4903-9101
Band classroom
Gentex GX-90
Largest kindergarten room and behavioral specialist’s office
Gentex Commander 2
Library physical therapy office and the stage
Greg’s grocery is a grocery store built in 1999. The grocery store has the main grocery area, a back area, sprinkler riser, loading bay and a small office.
Panel:
Current: EST 2
Original: EST 1
Current: Mix of EST Genesis’s and EST Integrity devices. All set on code 3
Original EST Integrity devices set on code 3
Pull stations:
Current: Mix of 2708-B And 270-SPOs
Original:270-SPOs
Other signaling devices:
Adaptahorn with Adaptabeacon for freezer failure
Tork Alert Simplex horn rebrand (flush mount)
Scott Middle School was built in 1970. The school has a 1 story main building, A detached gymnasium, and a detached auditorium. The school has a water tower because the school was in the spot of an old abandoned textile mile demolished in 1969 and the water tower is currently serving the fire sprinkler and most of the water supply lines.
Panel:
Main building panel: Simplex 4208 with related annunciator panel in left hall
Gymnasium panel: Simplex 4208
Auditorium panel: Simplex 4208 panel for main building: 4208 kept and connected to 4010 for smokes
Initiating devices:
Simplex 4251-30s
Simplex 4251-20s in office and basement
Simplex heat detectors
Simplex 1990s Trualarms
Some 4099-9001 stations in some areas connected to 4010
Simplex 4051s on 4050-80 light plates
Simplex 2901-9840s outside in weatherproof cases
Simplex Remote strobes
Simplex 2901-9838s replacing some 4051s
1 Simplex Trualert in the basement
P.A:
Rauland Telecenter U
Rauland square speakers
Simplex 10" bells for class change
Sprinklers:
Grinnell Sprinkler fittings
Grinnell sprinkler bell
Potter flowswitch
James Shopping mall was built in 1999. The mall has 4 anchor tenants and 190 other store spaces. The mall also has a 5 story parking garage as the mall is 5 stories tall. The main mall system also services 2 floors in the parking garage. All other 3 levels have their own panel.
FACP:
Main main: Simplex Simplex 4100ES w/voice evac and fire phone and a 4010 from the original install
3 levels of parking garage: Simplex 4006
Initiating devices:
Simplex ADA t bars with MAPNET II
Simplex 4099-9001s connected to 4010
Simplex 2099 t bars in parking garage
Simplex 4902-9716 speakers on the ceiling
Simplex 4906-9130s paired with the speakers.
Simplex 4903-9238s in older areas on the ceiling
Simplex white truealert horn/strobes in 3 stores: The apple store, The LEGO store and the Microsoft store.
Parking garage: Wheelock MTs set on bell and code 3 tone
Special systems in anchors:
Sears: Wheelock MB-10 motor bells with LSM strobes. Panel is a MS-5-UD-3. Stations are RSG-RMS-1Ts.
Belk: Wheelock AS devices on the ceiling. Wheelock NS in front of elevator and stairs. Panel is a Fire-Lite-Miniscan.
JCPenny: System Sensor MASS’s set on whoop. Panel is a Fire Lite MS-10-UD-3. Stations are bg-10s
Dillards: System Sensor Classics. Panel is a Fire Lite MS-5-UD-3
Pradon Middle School was built in 1951 as a 3-story, 575 student campus. A 2-story, 14 classroom and cafeteria addition was built in 1986. A new media center, gym, and classroom addition was built in 2009.
[*]Original System: Simplex 2001, replacing a coded IBM system. FireLite Miniscan 12/24 for elevator recall.
[/list]
Annunciator
[list]
[*]Current System: Simplex 4603-9101 in front lobby
[*]Original System: Graphic Annunciator
[/list]
Initiating Devices
[list]
[*]Current Systems: Pulls are all Simplex 4099-9002s, some of which are under Stopper II covers. Smoke detectors are all Simplex 4098-9714s. Heat detectors are all Simplex 4098-9614s. AHUs have Simplex 4098-9756 duct detectors.
[*]Original System: The 1951 building had IBM break-glass pulls, with two 4521-20s (one in the library, the other in the kitchen) and a Edwards 270-SPO in the choir room. IBM mechanical heat sensors were in a few places, but most of them were replaced with 2098s or TrueAlarms. The 1986 addition had 4521-20 pulls, and three 2099-9001s, and 2098 series smoke detectors. For elevator recall, there were System Sensor Ion detectors at each elevator landing, with an i3 and a System Sensor heat detector in the machine room.
[/list]
Notification Appliances
[list]
[*]Current System: Signals here are mostly Simplex 4906-9151 speaker/strobes. These can be found in all hallways, classrooms, the media center, cafeteria, old gym, weight room, locker rooms, band room, choir room, dance room, CTE labs, kitchen, and front office. Small offices and areas requiring additional speaker coverage have Simplex 4902-9716 speakers. Restrooms have Simplex 4906-9101 strobes. The new gym has Wheelock STH speakers behind wire-guards, along with 4906-9101 strobes. Outside, there are Wheelock ET70WP speaker/strobes. All strobes are sync’d. The system plays a slow whoop tone and the following message
[*]Original System: The 1951 building had IBM 4030-1 horns in the hallways, library, wood shop, metals lab, and gym. The band and choir rooms had Federal 350 horns on 2903 strobe plates (these were previously the cafeteria). The locker rooms had Gentex SHGs installed in 1994. There was a Simplex 4040 on the third floor hallway. The home ec lab has a Wheelock 31T horn replacing a 4030-1. The 1986 building had 2901-9806 horns on 2903 strobe plates in the hallways, cafeteria, and some of the larger rooms, along with a few TrueAlerts and a Wheelock 7002. There was also a flush mounted 2901-9833 outside. All restrooms in both buildings had 2904 strobes. Signal coding was 4-4 with the original IBM system, but changed to 90 BPM march time when the 2001 was installed.
[/list]
Intercom Head-End Equipment
[list]
[*]Current System: Rauland Telecenter VI
[*]Original System: Stromberg Carlson PowerKing
[/list]
Admin Phones or Mics
[list]
[*]Current System: Rauland TC6434 at receptionist’s desk, TC6402 in all offices and in the clinic.
[*]Original System: Stromberg Mic next to rack
[/list]
[b]Speakers, Call Switches[/b]
[list]
[*]Current System: All hallways, the media center, new gym, and cafeteria have Rauland ACC5WB speakers. Classrooms have Rauland ACC1400 speakers and TCDPB2 call switches. Office areas have Rauland ACC1400 speakers. The old gym has Atlas Horn Speakers. Outside, there are Rauland 3603 speakers behind wire-guards.
[*]Original System: In the 1951 building, the media center and hallways had Stromberg RH-29 speakers. Classrooms had RH-28 speakers and unknown call switches. The gym had RP-27 speaker horns. Areas that were the old gym had Simplex clock/speaker units. The 1986 building had Tandy power horns in the hallways and cafeteria, and Bogen speakers and call switches in classrooms.
[/list]
Bell
[list]
[*]Current System: Chime tone over intercom
[*]Original System: The 1951 Building had IBM RVF4015-6A bells in the hallways, old gym, media center, and in some rooms (like the home ec lab). There were two Edwards bells replacing dead IBM bells. Outside, they had IBM RV4016-6A bells, and a Simplex 4080 bell. The 1986 addition had Simplex 4090-1 bells in the hallways, in some classrooms, and cafeteria, and 4080 bells outside. Both buildings had buzzers in the classroom clocks.
[/list]
Clock System Master Clock Panel
[list]
[*]Current System: Integrated into intercom system
[*]Original System: Simplex 2350 replacing an IBM model
[/list]
Clocks
[list]
[*]Current System: The whole school uses Rauland 2520 clocks. These can be found in the classrooms, cafeteria, media center, locker rooms, and front office. Hallways have the same clocks but mounted on dual facing units.
[*]Original System: The 1951 building had a mix of IBM, Simplex, and Lathem analog clocks, while the 1986 building used Simplex analog clocks exculsivley.
