Make up a system
An antiquated school. Outdoor hallways with overhangs.
The main quad area in front of the school has dual Simplex 2901-9806 horns on weatherproof boxes. The office is right beside that, and it has a Simplex 2001 panel circa 1984. Signal coding is continuous. Right next to it is an older Radionics control panel from 1981. Signal coding is also continuous.
Behind that, wings of older classrooms can be found. Each hallway has a mix of MA sounders set to 800 continuous and 9806s. Both have red projectors over them. In each classroom, there are ESL 445CT smokes on the ceiling. The pulls are Fire-Lite BG-8s.
In the newer wings, Simplex 2098-9201 smokes can be found. There are also 2901-9806s in the classrooms. Pulls are 4251-30s (break glass with hammer type).
The gym has four ESL 1025C smokes, two BG-8 pull stations, and two MA sounders set to 800Hz.
The cafeteria is expanded from the old one. The old one has ESL 445CT smokes every 30 feet along the ceiling, and the new one has those 2098 smokes. Both of which have a Simplex 4051 behind a red flush grille.
In 2001, the system went through a re-do, and the smokes were all torn out. Replacing them are 449CTs, and ESL T-bars. The NAs are Wheelock AS’s set to unsynced code 3. The two 9806s at the front of the school were kept. AHWPs are now in the hallways.
