Hi every one. I need help. Im working in big building. I have Siemens fire Alarm system I had a trouble shows Smoke detector Multiple response and security DR relay. Both are blinking. And work. What can be the issue.
Moved to Fire Alarm Help
Nothing. Same text. Multiple response
Need more info here… Whats the model of the panel? If you aren’t in the industry, could you post a picture of the panel? My knowledge with Siemens is pretty limited but I’ll see if I can help get you an answer here.
Multiple Response means you have two devices that have been addressed identically. Presumably they are both the correct type of device for that address, otherwise I believe you would also have an Incorrect Device ID trouble.
Probably too late to help, sorry.
