I thought ever since this had become “The Fire Panel,” I thought I’d start doing my alarm pics thread in this sub-board instead of the main board. This first post shows pics of two schools right next to each other, where some of my former teachers now work at. The first is from a middle school built in 1957-1958, and is similar to the school I went to for junior high…
Their main fire alarm panel is a Notifier NFS2-640 system. It used to only be a Gamewell FlexAlarm system; I think they may still have it in their basement somewhere. But this is a “partial” upgrade that was done in 2010…
The alarm signals I saw were these really old flush-mount Faraday horns (like flush versions of the Type 2!) Several were red…
Others were gray. Note the IBM clock and school bell next to it (the school was built with an IBM clock/bell setup, but the current master time panel is a Simplex 6400.)
Notifier FSP-851 addressable smoke detectors, which were installed in many areas.
NBG-12LX pull stations were also installed in many areas where there originally no pulls…
But the old Gamewell pull stations are still active! I wonder if this could cause any confusion?
The school across the street is a K-8 school that was built in 1974, and is nearly identical to the K-8 school I went to for kindergarten (it was formerly a regular elementary school.) Like the above middle school, this place currently has two fire alarm panels installed…
The system is a Simplex 4010 tied into an older Simplex 4208 panel. The 4010 was installed some time in the mid-2000s, replacing a 4004, and is typically used for newer duct detectors. The 4208 is used for the existing pull stations and heat detectors. It’s an older 4-zone 24-VDC 4208 system.
Most of the alarms are Simplex 4051 horns on 4050-80 light plates. But look, three of the 4050-80s in the building are this rare version that has WHITE “FIRE” lettering instead of the usual black. This is the only place I have ever seen them.
All the other 4050-80s have no “FIRE” lettering. Note how the horn is pushed into the light plate so the front of the grille lines up with it (earlier 4050-80 light plates were designed like this.) That bell next to it is a Simplex 6-inch 4090 bell used as the school bell. There is one installed next to most of the alarms.
Most of the pull stations are Simplex break-glass 4251-30s. This one has the original glass intact…
But nearly half of the 4251-30s now have replacement glass in them (prior to at least 2009, many of these had NO glass in them.) It reminds me of my 4251-30, which has identical glass in it.
There are three of these alarms in the main gymnasium. The school bells in the gym are 10-inch instead of 6-inch, apparently so they would be louder.
The pulls in the main gym have those Simplex metal wire cages over them to prevent them from being smashed by balls and things like that. Two of them do not have the hammer, and one has the hammer but no glass.
At least three of the 4050-80s have the original lens missing! This one is right outside the media center.
The alarm in the kitchen has obviously seen better days…
Newer-style Edwards/AIP 270-SPO pull station underneath that alarm.
Simplex 4903-9236 horn/strobe located in the boiler room, which was redone around 1998.
There are also two of these Federal Signal pulls in the boiler room. Wonder why they went with these instead of Simplex pulls (as these were installed when the boiler room was redone.)
Simplex 4262-5 ionization smoke detector located in the cafetorium.
Other areas have these Simplex 4255-1 mechanical heat sensors.
These Simplex 2098-9806 test stations go to the duct detectors run off the 4010 panel, and can be found throughout the building.
For some reason this alarm and pull station are surface-mounted, compared to all the other alarms which are directly on the wall. It might have had to do back when the school had a modular building near that exit, or from a panel upgrade or something (there is also conduit going into the bell grille.) It almost looks as if there was originally no alarm there with the way the install job was done (as I have seen install jobs like this in older buildings that had a similar Simplex system installed during an upgrade/renovation in the 1970s.)
As of summer 2011, they installed a Stopper II cover over this 4251-30 pull station that had the break-glass frame removed earlier in the year. This is the only pull in the entire school with a Stopper II cover.
Simplex graphic annunciator in the main lobby. It appears to be a 1980s-style annunciator, which suggests the building may have had a Simplex 2001 system or something tied into the 4208 panel at one point.
The alarm setup at the exit near the speech office. This 4251-30 pull also had the break-glass mechanism removed, but didn’t have a Stopper cover installed over it.
