Need Help Wiring This (Changing my demo system)
Hi everyone, so I am changing up my demo system a bit and wondered if I could get some insight on this.
I wanted to eliminate the smoke detector (temporarily) because I just want a pull station, a silence switch, and my MDL module hooked up to 2 A/V’s with my power supply so that I can sync strobes in an upcoming system test that will feature the System Sensor P2R horn/strobe and the System Sensor SR remote strobe. Also eliminating the smoke detector (for now) will make it easier to wire everything and will make it easier as I may be getting a panel (Fire Lite MS-2 or MS-4) in the future. Keep in mind though, as of now, I don’t have a panel…system is running off a 24VDC power supply.
Thanks everyone!
This should do the job.
Thanks!
