Notifier AM-6000 Panel Programming
Hi all, first poster here and a newbie in the fire alarm category
I know my basic way around the Notifier AM-6000, and I am trying to get into the programming section only by interacting with the physical panel buttons.
I read in the manual in order to do so I have to put the jumper on the back panel to J1, go into programming (F1
button) , then input code 44444 to enter the programming menu, but after doing so it brings me back to the home screen, i doesn’t say my password is invalid or gives me any information, just sends me back
Please help
pics down below, black bar inserted to hide the owner
Hello! Never seen this panel in the US before, so I’m assuming it’s an international panel. If it’s anything like the Notifier panels in the US, then maybe the passcodes were changed? Have you tried any other passcodes? I know some panels will boot you out of programming if you put the wrong passcode in.
Hello, I have worked on these systems. Maybe you have tried to enter incorrectly or the code for the level is incorrect. maybe try without the jumper? just curious, what country are you in?
Most likely, this series of panels is still based of the am-2020 so if it does that, it might do it on this panel. Btw this panel is from the italian division of notifier, but not only used in italy.
Croatia
If I input anything other than “44444” id gives me a wrong password prompt so it has to be right. i tried without and with the jumper on J1 but no change
Unfortunately i am unable to find Notifier AM-6000 user guide that explains properly, there aren’t even obscure youtube videos about am6000, it’s a really mysterious panel haha!
I’ll try to contact Notifer Italia, though I doubt I will get a response.
Ah nice! I would reccomend to contact notifier as I have never seen this issue before. The panel is very similar to notifier am2000 and am4000 so maybe you can find better videos and manuals for it
make sure the jumper is placed correctly once you ve done it a msg ll appear on P FLT section than enter the password
