P2WH-LF Audible Silence
Are the P2WH-LF sounders from system sensor supposed to have an audible silence feature? I have put them on a NAC circuit with other devices (P2WH) and the rest of the devices silence but the P2WH-LF devices turn completely off. The panel is a MS-9050UD.
It should if you’re using it with System Sensor’s sync protocol & have either the panel or sync module configured correctly depending on which one you’re using, but other than that two-wire devices do not allow for separate audible & visual control.
The panel I’m using has an audible silence option, and the rest of the devices on the NAC sync properly. Could something be wrong with the devices, should I get different ones?
I honestly have no idea: everything should be working properly.
It was a bad device, thanks for the help!
Huh, okay then. Sure thing! :smiley:
