Found this beauty at West Shore Services in Allendale Michigan. It is siezed, but with some work it could run again. It is 16 port and most likely 3hp, single phase. These are very rare sirens and I hope to get this one day.
you could get that to work again?
Iām pretty sure I can, all it really needs is for the rotor to be freed which would be done when removing the stator and the motor cover is only dented so water should have stayed out of it. I think freeing it up and changing the wire leads will get it to run. Plus most of the rust is surface and the damaged parts are the intake and projector which can be easily fabricated.
