(Not my image)
So
So I have a 5820xl panel for free now ![]()
I got it last week and aLso wrong pic
That’s good I guess, but do you have addressable devices or monitor modules to use with it? (as it’s more-or-less useless without either)
I find that kinda hard to believe
It’s not: just as conventional panels need conventional initiating devices, addressable panels need addressable initiating devices, or barring that monitor modules, which allow conventional initiating devices to be hooked to an addressable panel (thus essentially acting as an interface between the two).
If you do, take a picture of “your panel.” Not being rude just kinda disbelieving that you use someone else’s image.
Why do you not have a picture of it even though you already have it? also thats a different panel compared to what you said. I think this is false. Please dont lie. Btw you arent supposed to be under 13 here
What makes you think that he’s under 13?
the emoji use and writing style
Ahh. Yes. To be honest I don’t even think he has a panel.
I haven’t took a pic at the time
Sadley no i do Not yet
Well you’d better get either as the 5820XL is basically useless without them! (though from what I’ve read it does also apparently have “Flexput” circuits, which can be programmed to be NACs, auxiliary power, or conventional zones, so that might work too)
Make sure to keep it on or off most of the time, don’t transition often. Biggest issue with the 5000 series silent knight panels is the PSU quitting after too many power cycles.
Your here too? Your in every life safety server
