The first big paragraph is just the introduction leading to the problem, I do suggest reading it but if you want the, problem is stated below
So a few days ago I got myself a used IFP-1000 off of eBay. The seller said he did not know what was wrong with it so he put it up for parts. I got it for $70 . Sounds alright for a panel that you donât know the condition of, but this does get better. So I waited a week or so for it and then it finally came. So it came in the original Silent Knight box, so that tells me I might have a working panel on my hands. So I open the box and their it is. By first glance I can see one big scratch on the bottom of the enclosure but it did not really matter. So the panel did not come with the key for the lock, but was unlocked so, first I took the lock and now waiting to get a new one. So after that I looked at the panel itself. Its was astonishing because this was really my first official panel (but I do know how to use it after 1 hour or so reading the entire manual ). So after admiring the panel I had removed the circuitry from the enclosure. I will be having, now to clean the enclosure due to all the dust on it, but it is not normal dust it is like brown powder dust.(EWWW) So after removing the circuitry from the enclosure I had found one major problem circuitry board, a group of jumper pins have been bent with the circuit on. I was the amazed that the circuit hasnât broken in half during shipping because the jumpers where pushing against another circuit bending its own circuit. Anyway, I took apart the board fixed that and cleaned plus dust it off. It looked like new but I did not know if it worked like new. So the next day I had connected it to power and it WORKED!! I was glad that it actually worked and I got it for $70
. After getting used to it and also programing it I had to now pay attention to the troubles and fix them. So the common troubles I had where the missing EOL (End-Of-Line) resistors and the missing batteries, But their was one special trouble I need help withâŚ
The trouble I have on my IFP-1000 is a âSLC Shortedâ. Now visually their really is nothing touching the SLC terminals but anyways, I took apart the board again and I blew it with some compressed air and then put it together again but still the same problem. Also one of two relays (The One On The Left) above the SLC terminals are getting warm. Now I need the help of all the members of âThe Panel Formsâ to help me find the cause of the problem and help me fix it. Please anyone Help!
