Simplex 2001 - Wiring the motherboard jumpers
That’a awesome! Simplex Time Recorder is one of my favorite companies. They made such quality fire alarm and time clocks and time recording systems. I am as well, older Simplex is the best. That’s really neat, I saw your two 2001s, they are very neat. I always wanted a 4208. I’m glad that you are working on your large 4208, it’s in great shape for it’s age. I’m definitely going to get both of those, I was just talking to the Simplex tech last night and he was asking me how I want the 4020 programmed. It’s got a bad power supply, which is why it was pulled out of service, but that’s something I can fix. It’s a two bay 4020. My elementary school had a 4020 as well believe it or not, they are very neat. Thank you. I’m glad you decided to get into computer information systems, that’s still a great field to get into and I hope that your 3rd year is going great. Thanks for the help with my panel.
That’s interesting, yeah I was thinking about that and now that you mention it, it seems most likely to me that the specifications were most likely changed which is why there were once jumpers installed.
I did notice that transistor Q1 on the main motherboard is not present in my panel when I unpacked it. Every other board I’ve seen online seems to have this transistor. Q2 and Q3 are there. Do you think this missing transistor could be why I’m not getting power to the cards? It possibly could have broken off during shipping or something, unless this transistor was not in place from the factory. From the solder pads, it’s hard to tell if it was there or not originally. There are no resistors connected to any of the terminals. Here’s the thing. None of the trouble lights have ever lit up on any of the cards, nor do they go into alarm when the test switches are flipped, which implies to me that power is not getting past the main control card out to the other cards, or past the meter card, although the meter card doesn’t show any sign of current flow either. With the original control card, no lights at all ever comes on besides the main green power LED on the board. With the spare control card, only the one trouble LED on the control card itself is steadily lit, while the rest of the cards remain dark. I’ve tried moving the cards around, swapping the zone cards for the dual zone cards, etc. and none of these do anything different. I am getting good voltages to the main board, I checked some of the voltages on the terminals at the top left and I have 30 volts from terminal 1 to 5 and 1 to 6 on TB4. My theory on why the trouble LED comes on with the spare control card but not the original, is perhaps that spare card is configured differently for some reason and allows power to that LED only. All of the solder connections on the board look good, I even checked the back of the board. The card slots look clean and nothing is broken.
The part numbers of the original one zone cards are all 556-915A.
The part number of the original single signal card is 556-031E.
For right now I have the dual zone and dual signal cards in there.
Thank you for the info on that, good to know that I can swap the zone and signal cards without reconfiguring. Thanks for the info on how the two types of zone cards will land differently on the terminals, I will keep that in mind.
That helps as well, thank you. Once I get the panel working and am ready to add the marchtime card, I will cut that diode on the control card. Thanks again for the help!
