how and why?
(apart from the age ofc)
Most of them were replaced
whys that?
did they have a flaw?
No, they were notoriously slow but most of the time it was an upgrade
if they were slow then wouldnt that count as a flaw then?
i do suppose that the system would look something like this? (unrealistic placements ik)
what?
i do things on roblox
Did you model that, or did you grab a random model?
it was pre built
someone made the code and models as seprate parts and i just put it together
trying to do it the first time i found it was no joke it took ages
i added 2 other cards to the bigger transponder (i think its called)
but ye it works just as fine
it dosent like all fire alarms as it can break their strobe, horn / siren
it works with majoroty of pull stations but if they arent reset then they go off again (annoyingly enough)
The simplex 2120 used the same audible devices you would see with the 2001 and 4002, as in 2903s, 2901s, and 2902s if voice equipped
initiating devices are also your typical 4251-20 pull stations.
what exactly is the setup you wish to make?
a setup that works XD
but ye
i want the seupu to be era realistic (the year the 2120 came out and the devices that wre a thing then)
ill make a seperate section of family type, all (era and family) and family [hint: ill do all cuz i like those alarms (depends lol)]
Then yeah what i said earlier, 4251-20 Pull stations on zone cards, and typically 2903 signal plates with 2901 horns/bells, 2904 indicators, and/or 2902 chimes on your signal cards.
If its a voice system then it would be the same initiating devices, but the notification appliances will be 2902 speakers, or possibly 4090-91 speakers, which are rebranded federal signal/autocall speakers.
Are you using Scimitar Raccoon’s 2120 models, or something else btw?
Definitely older 80s Simplex devices. If we’re talking about the voice evac panel, then maybe Simplex life alarm 2903 speakers with the classic Simplex light plates. Maybe even the rebranded simplex speakers with the same design as the federal signal speakers but in very rare cases. It’s normally used with old devices
correct that i am mimi2
What’s your username?
Likely used 2902-9711 speakers as well, which are just rebranded AtlasIED speakers pretty much
