Alright, so my 4005 is all ready to go as far as hardware. New CPU, new power distribution board, a new 4 point IDC card, and a new 4 point NAC/Relay card. I’m having problems with the NAC card.
No matter what I do, I can’t get the four output troubles to clear on the card. I have the first circuit on the card set as a signal circuit, on until silence, and my second circuit I have set as a visual circuit, on until reset. Both relays are plugged into the correct pins on the card. I have the correct 6.8k ohm, 1/2 watt resistor on my strobe on circuit 2, and I’m still getting a trouble. It wasn’t flashing, either, when I activated the panel.
My 3rd and 4th circuits I’d like to be alarm relay circuits, like for a test station LED, but I have no idea how to program those for that. When I go to my relay points, it just says that no relay points exist, but I don’t know how to add them. Is there also a way I can just turn the two circuits off altogether? Either alarm relay or disabled altogether, either of those would be fine with me.
Can someone provide me with insight on how to program it correctly? This panel is harder to program than the other ones I’ve owned in the past, and it really is a pain in the butt.
Thanks in advance.
