Hello, I have recently got a simplex 4010ES fire alarm panel but the problem is I cannot figure out the Level 1 Access passcode any ideas on how to reset to default code?
Hello. Unfortunately simplex es panels can only be programmed through a PC programmer provided only by a simplex technician. As far as i know there is no way to reset the panel using the front display. Your best bet is to either get in contact with someone at simplex and see what they can do or try to sell it and get a legacy 4010 or something similar.
Level 1 access on all Simplex panels is the default base user operation. There is no passcode for Level 1. You’ll need Level 3 access for disabling points and running some maintenance operations. Level 4 will allow for restarting the panel and running all troubleshooting tasks and reports. Unfortunately there is no front panel programming for any ES panel (4007es, 4010es, 4100es). Passcodes and points can only be changed through the PC programmer.
