I have simplex 4100ES fire panel which recently it has shown Crash 98: LCD failed to initializion failed. I need help on this. I have attached picture of the displayed error
i found this on the autocall website,
https://www.autocall.com/resources/es-programmmer-revision-40104-software
if you install it and use the ip file transfer tool, you might be able to extract your configuration from the panel. You won’t be able to open it but i can and might be able to help you from there. You might be able to reflash the screen afterwards and could fix the issue if it’s just firmware corruption.
Same problem how to resolve this problem
the best way that i would do if my PC had a problem was to reboot the thing
idk if that works
Can you reflash the FUI binary files?
Rename those from .pdf to .bin
FUIBoot_104.pdf (102.1 KB)
FUI_1.05.pdf (231.7 KB)
