Hello everyone,
First, I would like to mention that I am a beginner and recently started working in fire protection after obtaining my certification. I’m currently handling fire safety duties in a large building.
The issue began when a new store moved into the building, and a worker accidentally damaged a sprinkler flexible hose, causing water to enter the detector.
I quickly replaced the affected detector, but there was no pulse signal, and after checking the graphical interface, I noticed several changes:
- The detector that had water damage still shows “No Answer” even after replacing it with a new one.
- 1 “Head Missing.”
- 2 “Bad Answer” (these detectors are located far from the construction area).
All of these detectors are connected to the 4090-9118 relay module with address 5. The detectors in the construction area are not receiving a pulse signal, while those outside the area are receiving the signal.
I checked the voltage, and it was 34V (normally, a working detector should read between 24-26V). Suspecting a short circuit, I disconnected the detectors, but the graphic interface still shows that they are connected normally.
I replaced the 4090-9118 relay module, but the issue persists. The 4100U system is reporting the following troubles:
- CARD 10, IDNET2 CARD - IDNET FAULT SEARCH
- CARD 10, IDNET2 CARD - IDNet+ Earth Fault
- CARD 10, IDNET2 CARD - IDNet EXTRA DEVICE
- TRUEALARM SENSITIVITY MODIFIED - TROUBLE POINT
- No Answer, Bad Answer, Head Missing…
I currently believe the problem lies with the Simplex 4100-3109 | IDNet 2 Module. Most of the errors are related to card 10.
I also noticed that one of the boards connected to the motherboard has a red light on it (while other 4100U systems I checked had a green light).
I’m not sure which board this is, but it seems to be related to data communication since it uses fiber optic cables.
What do you think could be the most likely issue?
Any help would be greatly appreciated. I’m working in South Korea, and it’s very difficult to obtain information here.
