Hi everyone I recently got a specter alert classic model P2475. And I really don’t want to hook it up to my simplex panel due to the work. I tried powering it with 27 volts and it did nothing but it’s rated for 20-30 volts. I then powered it with 2 6 volts and it made a small noise but I believe this means it was under powered. I’m lolling to. Get a transformer for it. I want a transformer that can do ac and dc. I’m not sure which brand or type I should get. Any help will be much appreciated.
If it’s the one that I sent you, there needs to be wires connecting the Horn + Terminal to the Strobe + Terminal and the Horn - Terminal to the Strobe - Terminal, otherwise it won’t work.
Correct wiring (minus power input) on the left, incorrect on the right
By the way, transformers are AC only. They use induction, and that only works for AC. You could need a power supply to convert the AC from the transformer to DC.
Don’t you confuse me on saying that “transformers are AC only” and other stuff (Sarcastically saying ). To restate what you said, transformers connect to AC power (The energy that comes out of your wall outlets), and TURNS IT into DC power. Now the power of DC a transformer converts depends on the transformer.
Transformers do not turn ac power into dc power. That’s what diodes/bridge rectifiers are for.
In a power supply, a transformer turns wall voltage (usually 120) into a suitable voltage for the specific use. Then, the bridge rectifier turns the AC supplied by the transformer to DC.
Ah, I get you. You are talking specifically on what a transformer is and a bridge rectifier and etc. Lol, I think we confused each other because first, I know what you’re talking about but for me instead of calling a power supply a “power supply” I call it a transformer and I got used to it not knowing W*F i’m talking about and stuff like this happen. I got to lay off the Optimums Prime now :lol:
