Have you seen them? My local Targets are like such. Red horns on the poles and white RSS strobes on the ceiling tiles. There’s a wall-mount horn/strobe by the restrooms. I find such an interesting system.
DonutHeaven, a small store somewhere in San Bernardino. They had a Simplex 9838 (I’m not sure of it, just looks like it.) and had a Wheelock RSS next to it, pretty cool.
I found this video a long time ago, notice the MASS and Gentex strobe. I’m guessing the designer/engineer preferred Gentex strobes, and a tone on the MASS.
It’s done a lot in malls, department stores, and other buildings with high ceilings in order to more efficiently fulfill the required sound and strobe coverage. I don’t know the exact formulas for determining the placement of audible and strobe appliances, but sometimes separating the appliances allows designers to use fewer of one device type and lowers current draw. For example, rather than installing 4 speaker/strobes on each wall of a rectangular atrium including an upper-level balcony (adding up to 32 speaker/strobes), a designer may be able to use just 5 high-wattage ceiling-mount speakers which will have better sound coverage by pointing down rather than out. Now, the designer can get more creative with the placement of strobes and could perhaps cut down the original quantity of 32. Cost, code, and current draw all go hand in hand and pretty much drive everything.
I have seen this quite a few times. Our local Home Depot mostly has wall-mount Wheelock NH horns and ceiling-mount Wheelock RSS strobes (they have an EST system.) Though I do remember seeing a few NS horn/strobes as well!
The Conant Science Center at Bridgewater State University (Simplex 4100ES voice-evacuation system) has this in some areas; remote TrueAlert speakers next to remote TrueAlert strobes. Maybe this was to make wiring easier or something? Other areas have TrueAlert speaker/strobes…
Yeah. They’re not very common in my area either. Both the Targets in my area are the only places that I’ve seem with systems like such. I think the reason why the Targets use separate horn and strobe NAs is because there are plenty of areas in a large store that only need strobes. In smaller areas of the store, like near the restrooms, where both sound and strobe coverage is needed, they have wall-mount horn/strobes.
I still think it is neater, less time-consuming, cheaper, and requires less labor to just install horn/strobes on the ceiling along with just strobes. There’s no reason to have a horn only device mounted on the walls.
This school had installed Wheelock MTs, and Wheelock LSM strobes. I thought it would probably be much easier to install just the horn/strobe combination of these.
