I have a Faraday rebranded RMS-1T pullstation, and when I screw the terminals all the way in to hold the wires, they just keep turning. ANy idea on what’s going on?
They have probably been cross threaded and need to be replaced if they don’t tighten.
How can I replace them? They won’t even screw out.
Sounds like you blew out the threads on the terminal block.
It’s busted now. Cheap, low quality terminal blocks have this problem if you over-tighten.
You could try using a screw whose diameter is slightly larger though…
It honestly wasn’t me. :roll:
That;s the problem, I can’t get the screws out either.
Jam a flat screwdriver under the screw head and use it to push up on the screwhead while you try to unscrew it… That’ll slowly back the screw out
Sweet, thanks!
