The Notifier Inspires are here
After hearing roomers for like 2 years now there actually here.
The Notifier Inspire is now on the Notifier website with a lots of new stuff.
The Onyx series still remains on the Notifier website but I’m not sure how long will it last.
What’s your opinion on this?
My opinion on the Inspire is that I don’t really like it
The licenses are nothing but unnecessary. It basically locking features behind a paywall like how EA locked stuff behind a paywall.
Also I feel like the DVC needed a update since the DVC they used on the Inspires is the same as the Onyx which I think looks bad
(Those DVC buttons look bad with the rest of the panel. It’s ugly)
There are some stuff I like about the Inspires like Self Test, and the new CAB-Es. I honestly think they should’ve made a NFS3-3030 and a NFS3-640 and put those features in there. That’s my opinion on these Inspire panels.
In reality they sort of did combine the 320/640 with a 3030. Both versions (N16E and N16X) now use the 10” touchscreen display and now the main board for both has NACs incorporated, which the 3030 did not. The 640 and 320 did have onboard NACs. The 16E is capable of 3 loops and has its own cabinet, similar to the 320. I am not a fan of the licensable features, especially for CLIP mode use, zone coding, and zone additions. That feature will cause headaches in the field. The new ACM modules are cool though, they can be used as buttons with fully configurable LEDs or LED only and you print the label per your configuration. I think the overall aesthetic is very 1980’s looking and sort of unsophisticated. Not my cup of tea but the objective isn’t how it looks it is how it performs. The self testing smokes are cool, I have seen them in person, but you have to have CLSS to use them. I will just say I am not a fan of CLSS.
I forgot to mention. Is that there’s a touch screen display already out for the ONYX series (NCD) which can run RLD touch screen annunciators. Also you can thow a 3030 CPU in a Inspire Cab E with a NCD and you basically have a Inspire with out the microtransactions and with out the Self Test combability. The Inspire had potental but It was mostly wasted.
Here’s what is probably the first-ever video of an Inspire with voice.
(I asked in the comments if the system is in Massachusetts, because the message includes “The signal tone you have just heard…”. The answer is no - this is in Tennessee.)
you can buy an annunciator for an Inspire on eBay
Link
According to this FAQ, the license-required features can still be used without a license, but doing so will cause a “license not present” trouble on the system. Can this trouble be ignored in real life safety systems?
Notifier appears to have updated the INSPIRE series in October 2024 so that all panels will come in an “N16e persona” and require an N16-XUPG license to access N16x functionality. Compare the October 2024 datasheet with the July 2022 datasheet. It is unclear whether the pre-engineered “N16E” can be upgraded to an N16x using an N16-XUPG.
I recently acquired an N16e, manufactured January 2026. I managed to clear all but one of the troubles. The last trouble requires VFT to fix; maybe I’ll get my hands on VFT 12.4X in the future.
As for my initial impressions: it’s what I’d expect from a high-end Notifier panel. Performance speed and functionality is on-par with the Onyx panels, but at least there’s no more System Initialization trouble. The licensing tokens are totally unnecessary, and I wish they kept more front panel programming as they did with the Onyx series. The touchscreen is very responsive, probably the best out of the other touchscreen panels I’ve had (S3 and 4007ES).
Here’s a clip of it in action: https://www.youtube.com/watch?v=IBmR79vdUlQ
The Inspires now have new N16-FSAE-10 and N16-FSAE-20 licenses. According to the Gamewell-FCI Elevate datasheet (more about that series here), FSAE is short for Fire Service Access Elevator, which is required by NFPA 72 (section 21.5) to have the temperature monitored by the fire command center, so this is a new integration that can be accomplished using any PTIR, COPTIR, or self-testing photo/thermal detector instead of a separate fire service access elevator monitoring system. I initially misinterpreted the license as being required to use any of those detector types on an Inspire, but I believe those detectors can still be used for non-FSAE purposes.
Information on the recent updates can be found here. It looks like Notifier is locking the new features behind an N16-XUPG2 license.
