I’m wanting to find the data sheets for the Simplex 4903 series FreeRun horn strobes from the 1990s, particularly alarms like the 4903-9217 and the 4903-9238. I spent awhile looking on Simplex’s website, and the closest things I got were the data sheet for the https://www.tycosimplexgrinnell.com/wps/wcm/connect/c5edaa06-63aa-413c-9d3d-a8fe958a4cd5/4901-9822.PDF?MOD=AJPERES&CACHEID=ROOTWORKSPACE-c5edaa06-63aa-413c-9d3d-a8fe958a4cd5-kX1QA-G 4901-9822, which appears to be a horn-only version of the 4903-9238, and the data sheet for the https://www.tycosimplexgrinnell.com/wps/wcm/connect/7b234d6f-315e-4891-ac08-2834b4d93249/4903+Series+3.PDF?MOD=AJPERES&CACHEID=ROOTWORKSPACE-7b234d6f-315e-4891-ac08-2834b4d93249-kX1Q9g- 4903-9252. Anyone know where to find them?
Fire Alarm Resources has SOME but not a lot… May be worth a look though!
For example, here’s the datasheet for the 49034904 light plates: http://firealarmresources.com/wp-content/uploads/2013/06/Simplex-49034904-AudibleVisible-Plates.pdf
Here’s everything Simplex Notification Appliances on the site there, but sadly I do not see the particular datasheet you’re looking for. https://firealarmresources.com/simplex-notification-appliances/
I also found an older installation manual: http://mtnbell9845.yolasite.com/resources/4901-4903.pdf
AWESOME! Thank you so much!!
After some further Googling, I was able to find the http://www.firebrasil.com.br/site/pdf/Simplex/Fire/4903-0009.PDF data sheet for the 4903-9236! I thought I’d post it here in case anyone else some time in the future is looking for it. Thanks again for your help, Zach!
Hi there! I am having trouble finding data sheets for the 24 FPM 4903-92XX Electromechanical Horn/Strobes (From January-September 1994) and 4903-91XX Speaker/Strobes (From 1993-94) & 24 FPM 4904 strobes (from 1993-94). I remember I used to see a data sheet that had a bunch of different Simplex Speaker/Strobe units called 4903 & it was all 60FPM models. I clicked on it in January & all the sudden it is gone but there was a picture of an old 4904 in the photo. And I noticed there were extra speaker/strobe models like the 4903-9145 as an example (Vertical mounted counterpart of the 4903-9144) listed on there which is essentially a 110CD counterpart to a 4903-9147. They also had models like 4903-9143, 4903-9302, 4903-9304, 4903-9306, 4903-9325, 4903-9334, 4903-9335 & 4903-9336. These datasheets are nowhere to be found.
