My college has a SpectAlert ceiling only speaker/strobe in some of the hallways so System Sensor does make speaker only ceiling mounts. Not sure about the horns.
Do you mount your horns all around your house?
I was talking about the horns, but you are correct about the speakers.
I only have a “mini” system on one wall of my room, so no. I might be getting a larger system that will still only be contained in my bedroom.
What happened to the smoke
I think I explained this in the video, but I carelessly tested it with a match, and burned the plastic.
Oh so that is a heat as well
Yes, it is a photoelectric detector with a built in thermal sensor.
Aaaaahhhhhhhhh
Is it fixed heat? If that is so, isn’t it useless now?
It is fixed temperature, BUT it is a thermal sensor, not a heat detector, so it is reusable.
That’s nice because its more then 1 time use
Yes, I like it. My new detectors have the built in thermal sensors. I can test them with just a hair dryer set to hot. ![]()
my chemotronics 601 is rate of rise and fixed so that is nice
