Vista 20p Fire Question
What do you mean?
Depends on what wiring method you use.
Can you explain this directly? I’m still learning all of the Vista 20-p’s features. What relay?
There is a set of pins which have low voltage outputs on the Vista20p. These outputs can be programmed in *80 to do what you want. These outputs can be wired to a relay coil and you can control the nacs that way.
The relay is not provided with the panel but it will work this way.
Here is more info about it.
Are there ā€œon until silencedā€ and ā€œon until resetā€ relays on a vista 20p?
I planned on wiring an exceeder, would the strobe flash at all?
The strobe would flash in code 3. Not sure about the horn, I don’t think it’s a good idea.
Honestly I plan on putting in 747 sirens anyways, I am interested in putting a spectralert classic 12v remote strobe for visual notification.
Maybe you could set a zone to fire output, and have it flash the strobe
