I have the ES2 Slow Whoop.
@SP2R1224MC I’m back, here is a folder of IRC-3 LifeLines 2002 tones from a CD:
https://drive.proton.me/urls/E290PHPKX8#YglOrHNaLADN
The file is called SLOWWHOP.wav, it’s in the “FCCA” folder.
FASTWHOP.wav sounds like a hairdryer. Definitely didn’t know it would sound like that.
Have the Siemens XLS Messages & Tones:
Siemens XLS Voice Evac Messages & Tones
You forgot to switch it to “Anyone with the link” as it says “You need access”.
Fixed it, Something weird that google does.
Not really: they have uploaded files set to “Private” by default for likely a good reason. Thanks though.
https://drive.google.com/file/d/1OCrrZHyjzq5XDpZNvMJX4wCGs9hPLS0c/view?usp=drivesdk
Basically a cursed MXL message. (Lobby is mentioned)
Going by the way that message sounds, you made that with AI didn’t you?
Used the male voice to make multiple phrases. Used a tool to merge them into a message. Since “Lobby” is rarely used, I found this video of it. https://youtu.be/WT557vxN7LA?si=d8IaSf1O7FyeBp4Q Original phrases from the DML were used when generating each phrase into audio. The script is: (May I have your attention please) (May I have your attention please) (a) (fire) (condition) (has been reported) (in) (the) (lobby) (while this is being verified) (please leave the building by the) (nearest exit) (do not use the elevators)
Here is the phrase in pure audio form. https://drive.google.com/file/d/1T2wJGv8PAJI5fmTqzyuoP9wMXSfYzeqJ/view?usp=drivesdk
None of that really seems to answer my question, but okay.
I get that one of the phrases sounds a bit off. Probably the 13th phrase in that script. I used Fish Audio to generate each of those phrases. Some of these I had to recreate because there was no Audio of them. Since I don’t own a DMC-1 I can’t get the library original versions of these in audio format.
