Wei's Collection
most of what will be posted are less common items and might not be everything I have
System Sensor SYS-HSR
System Sensor P2475RLZ with Xenon Strobe
System Sensor S2475RLZ with Xenon Strobe
System Sensor P2475RLZ With LED Strobe (1st Generation for LED models)
System Sensor P2475RLZ with LED Strobe (Current production model)
System Sensor P900 (Looks identical to P2475RLZ LED 2nd generation)
Shanghai Songjiang SGJ-1 Horn Strobe (a very good spectralert clone)
RSG RMS-1P Pull Station in Chrome
Firecom F900-943 Pull Station
Firecom FRSS-24MCW-FW
Firecom FE70-241575W-FR
Firecom RA-40 Annunciator Shell (internals got removed)
Wheelock ASB-24MCC-NW Horn Strobe
Wheelock MTWPB-2475W-NW Horn Strobe
Sigcom SG-42SK1-NY Dual Action Pull Station
Autocall 4050-001 Pull Station
That SGJ-1 is really interesting! Do you have a video of it?
yep its on my channel
You got a lot of rare variants of otherwise common device series series! I was wondering if we can put the chinese SpectrAlert Classics on the System Sensor SpectrAlert Classic page on The Fire Panel Wiki since this would go great as regional differences between each variant of the SpectrAlert Classic.
sure go ahead, i got photos of other models if you need them
You can send me the photos of all the variants you have of the other models with descriptions of them so I can put them on the wiki page as well.
alright ill gather some and dm you
Do the p700 p900 and p2475rlz led work on sync module like mdl? can they have audible silence? also, can they be coded using sync module? if they can can you send a video all of them (s2475rlz p2475rlz p900 p2475rlzled ) wired on sync module?
wei huan i found a close clone to p900 on taobao its 19 yuan and it hass the same mounting and terminals
https://drive.google.com/file/d/1khN4VZXhGlpspKutGDBn-m4lh5D0W96y/view?usp=sharing
its probably a rebrand of this Fire Strobe Light And Siren Fire Alarm 2 Wire Conventional Strobe Sounder For Fire Alarm System Horn Strobe Sounder - Buy Red And Blue Fire Strobe Lights In Building strobe Light 220v red And Yellow Strobe Lights Product on Alibaba.com
none of the LED models will work on MDL module. it is very differently designed compared to the original xenon design circuit wise, the LED models cannot do audible silence because it is 2 wire and does not sync.
Clones do exist but most are addressable and only work with certain locally made panels
I was wrong it is encoded and needs a encoder
By the way I saw 10 p2475rl xenon with 1 sys-hs on mdl sync module at hostpital
I found this on taobao for cheap once but the shipping was expensive lol
