Good choice of videos. Now, TrueAlert Speaker/Strobe (and whoever else wants to know)-
There is a good logical reason why the 4050 sounds a lot lower than the 4051.
The wall current we have here in America is of course 120VAC. The frequency of that AC waveform is 60Hz, or 60 waves per second.
The 4050 is an AC powered horn. American AC is 60Hz. What do you think it would sound like? (a 60Hz buzz.)
The reason it makes that 60Hz buzz is because it uses the AC waveform as its oscillator, not a mechanical bell-like mechanism.
Now, some people might say “Oh, but it makes a 120Hz buzz!”
120Hz is just 60Hz, but one octave higher. That is caused by the metal striker hitting an object on every movement, instead of every other movement. So, it sounds like it’s going twice as fast. Got it?
The 4051 is a DC horn. DC is just a straight line at 24 volts. How do you get oscillation on DC? You can’t and shouldn’t.
The 4051 has its own oscillator built in, functioning EXACTLY the same way as a mechanical bell. A solenoid (in this case, a big iron slab behind the horn) pulls with incredible force on the striker, which is very springy. Once the striker is pulled up all the way, a contact is broken. The striker is released, snapping back on the diaphragm, making one loud “pop”. Now, the circuit is connected once again, and the striker goes back up, SNAP, back down, up, SNAP, you get the idea.
This can happen at a much faster rate than 60Hz, giving it a higher pitch. Different mechanical horns use different diaphragms, different strikers, magnets, you name it. That has a LOT to do with its tone and pitch, since they all affect the speed.
Here’s a link to how a mechanical bell works (Just apply that same principle to a DC horn.)
http://www.britishtelephones.com/howbuzz.htm
