Hi all, I recently got a fully functioning Wheelock AS-24MCW in my first eBay haul. It sadly came without a mounting bracket and screw. I was wondering if there’s away to make a custom mount and what screw is needed. I’ll put pictures of the device below. Thanks, Alex.
I’m pretty sure that older Wheelock AS alarms only do continuous unless they are coded by a Wheelock sync module.
I figured that out. It has the connection, it’s just missing the jumper box that goes on.
Here’s what it’s missing.
I guess this one is capable of it then. I guess I should have known that it is a newer one. Only the newer ones have plastic on the back. The older ones that would not have that option have a cardboard back.
Alex, I may have a bracket for that device. I’ll check and report back.
If you don’t have one it’s fine. I do have the materials to make a custom one for it.
Alex, I have one but it’s attached to a new device still in the box. I have a used weatherproof back box from a Siemens branded horn strobe that you are welcome to. It it used in place of the mounting plate for wet applications.
I’m doing an update. I found the bracket that was supposed to come with it. It fell out of the box and I hadn’t noticed. I unboxed on my couch and it ended up between the cushions and the back.
